Dual rate?
Not trying to start an argument Jaz, but actually, expo has nothing to do with the speed of the servo arm, it's controlling the amount of throw per a given amount of stick input. It may be perceived as speed, but it is not.
A servo that is being controlled with -50% expo vs. the one with 0% expo will both hit the EPA at exactly the same time. The one with 0% is on a linear curve so at half stick input, or with the stick at mid point (imagine an airplane radio) the throw on the servo horn will be half way. It's a one to one relationship. The one with -50% expo will be less than half way on the servo horn with 50% stick input.
Look at it like this:
Stick input, Throw w/0%, Throw w/ -50%
10%, 10%, 2%
25%, 25%, 10%
50%, 50%, 25%
75%, 75%, 70%
90%, 90%, 89%
100%, 100%, 100%
Expo dials out throw around the center point of the wheel, it does not change the transit speed of the servo arm.
10%, 10%, 2%
25%, 25%, 10%
50%, 50%, 25%
75%, 75%, 70%
90%, 90%, 89%
100%, 100%, 100%
yes. You are correct..Its just easier to explain in terms of speed, as you turn your radio wheel, or pull the trigger. It will not get your wheels to full throw at 1/4 turn from your radio, or your throttle to WO at 1/2 trigger..I guess speed is a bad way to explain it...trying to make it as simple as possible..Thanks for the correction
I use exponential on my throttle. I had an 8ight RTR and the engine (Mach 427) was a bit of a monster. Power seemed to be non-linear without using exponential - it felt as if 50% throttle squeeze was more like 90% engine output.
Exponential on the throttle allowed me to keep it under control as if it were a more average .21. And now I'm just more accustomed to using it, even though I no longer use that engine.
p.s. The Drake aka Dan Drake has taught me well!!!
#21
Now everyone pay attention because I have been thinking..(can you smell the calamari Burning)
Throttle servo with positive Expo, negative expo, and No expo..same servo
you pull the trigger..how quickly it gets to WOT is all relevant to the expo setting as the bigger the curve, the more you have to pull the trigger to reach WOT..... taking more time!!! I win
#22
Damn Its Dan! I Thought it was Don!..I've been telling people the wrong name...every time someone attacks you for bringing up "The Drake" I been telling them its Don..after they squirm a little first....
#23
Originally Posted by [email protected]
Hey guys,
What does dual rate steering mean exactly? What are the affects of turning it up and down, and how do you adjust it on a spektrum dx 2.0? Am I totally off here? lol
Thanks alot.
Thanks alot.
meaning if you look at your servo horn moving if it is still moving when wheels are at full turn you need to turn down your epa if at full turn you can still move wheels to turn side more you need to turn your epa up. dont for get to do both sides. also take air filter off motor and set throttle epa so that the carb inner slide just gets to full throttle if dont set it will ruin carb and servo
