Why no boots on cv axles and joints rc8t?
I allways notice allot of wear on my center cv joints. The front and rear center drive shafts take a beating with no lubrication and running dry. All manufactures would have to do is incorperate a rubber boot to hold some lube in the cv joint and I bet almost all the wear would be eliminated.
The rear shafts on my rc8t are a good example but why did they stop there.
Excellent question
I might start looking for a boot that will fit. I found traxxas boots for there revo cvd but the shaft is to big. I'll keep hunting
Would have been nice....
Even on the RC8 buggy I have run into this. My front CVD started squeaking pretty loudly. Had to hit it with a shot of WD40. Stopped the squeak and not attracting too much dirt. Boots would have been nice. GMK makes some boots that might work with those joints, but I haven't tried them yet...
Gotta link to gmk?
I was looking on tower. I'm gonna pick up shock boots and whatever axle boots they have and see if anything works.
Go to amain and search for GMK. I would post the links but apparently I do not have enough posts here yet.
ok i will. I can't imagine how much less friction there would be with the cv joint being nicely lubricated. I also had a weird squeeling noise once in a while. Turned out to be the cv joint just being bone dry and metal on metal. Can't wait to grease them and slap a boot over the whole thing.
The factory losi boots do not work. They let the sand in and keep it in . Its worse then running them dry. the gmk boots look the same as the losi but I dont know if they work. It appears that the hole in the losi boot is too big to seal it. The boots by dynamite for the tmaxx work great with grease inside. DYN7687 is the part number. They work great on all losi buggy and truggys. The losi 1.0 buggy on the rear drive shaft is the exception. The battery box can flex and come into contact with the boot and tear it. It lasts intill the car gets the right kind of hit then its torn. If put on new you will not wear out a center cvd.
luckyhomes thanks I just ordered the dynamite boots to try out. I appreciate you sharing the info.
^ oh I should add the reason it works so well is because it puts like a wax coating over whatever you put it on [dont worry it dries clear...] and it wont attract any dirt or dust.
Idk matter of opinion I guess. boots are just more rotating mass and drag...plus I can still imagine some crap getting inside of them
I used the sportwerks boots on my RC8T...I had to stretch them on but they are still holding strong!
http://www.amainhobbies.com/product_...oducts_id/7214
You can sort of see the one on the rear shaft in this pic:
