Novarossi parts compatibility
I was wondering if the heatsink heads are interchangeable for novarossi small block engines, specifically between the RS12 based engines and the newer NS12 based engines? Reason I ask is because i want to buy a Kawahara/Zac Racing heatsink head for a NS12RRL5 and i'm not sure if it will fit.
Chuck
Chuck
Yes they are
Can RD Logic .12 Turbo Speed One-Piece Pipe Set be used on the NS12 engine?
thanx guys
Does anyone know what Pull-Starter fit NS12? Thanks.
? is it all pull-starter could fit? i want to make sure. i don't want to buy a pull-starter n then find it doens't fit.
OK. Do you know which pull-starter should I get?
You can't fit a pull-starter onto an NS12. The crank is bigger than the old CX12. If you want a good pullstart motor, look into a CV-R or a 15 CV-R.
Get a box and be done with it once and for all. Think about it: No more blisters, no more missed qualifiers because the stupid wire or one-way bearing gave up, less weight, more power, engine cost is less, more space in car, Keep cranking til it fires up, without you breaking a sweat.... I don't see too many racers going back to pullstarters after they buy a box.
If for some reason you have to have pullstart because you are using it in a maxx or similar, get the CV-R or TR form O.S.....
True and not forgetting higher CG with the pull starter... But I think for some beginner races in certain countries, the pullstart is mandatory.
Thanks guys. Then I need to buy a starter box, and that's it.
