T.O.P. Racing "Photon" 1/10 EP Touring Car
#8461
What's up TOP Racing USA!
Just trolling RCTech...been awhile, 1.5 years.
Edward Jack give me a call!
OD...hope all is well.
P2
P2
#8462
#8463
#8464
Hi to all TOP pros out there. Need a little help here on the chasis setup. I run a Photon with lipo chasis on 17.5 blinky. 0 at the motor also. Pure blinky on outdoor track medium to high traction with abt 30-40 meter street. Can anybody assiste with the setup such as shock oil, toe, camber, spring rate, sway bar as i'm new n bought the kit used. Running on Sorex 36/40. Thanx.
#8465
OK I'm sure its been posted on here before but can anyone explain how changing the bell crank insterts and moving it forward and back change the steering input and feeling of the car. Also by moving the tie rods tot he forward hole on the steering blocks does that make the steering feel more lazy or qwicker? Thanks for any help.
#8466
Hello everyone
Anyone could point me towards a setup sheet for very, very low grip carpet ? It's for a technical , small track. I tried the stock setup, the car felt really good with a speed 6, but was slow. Thanks ! (P. S. the mandatory tires are MM32)
#8467
I've browsed the photon wiki setup but none seems relevant for super low grip carpet...
#8468
Need to get me some Photon parts...where's the best place to order from in the US?
#8469
I found the kit setup didnt turn really well... Maybe your car is easy to drive but if it is understeering maybe you could fix that also... Use a little less rear toe (For stock classes) for starters...
#8472
#8473
Everything is in stock.
Or you can order through RWH
