T.O.P. Racing "Photon" 1/10 EP Touring Car
#7786
I'm in the process of changing the servo around. Just double sided in place at the moment (To check fit and mark holes for servo posts) and it looks much better. I run the hobbywing 120a with the 4 cap board so space is an issue with the old setup. I look forward to running the receiver on the deck!
Hopefully some new chassis plates land in Aus soon for us to try (Exotek)
New batch EXP's are in stock and a bunch shipped to AUS already, Thanks!
THE SHOP
#7787
What should I shoot for final drive on top photon 17.5 d3 with Tekin non boost
#7789
I am looking for a 17.5 outdoor setup using the exotek chassis. I assume the places I will be racing will be low to medium traction, but this is my first time racing outdoors so not 100% on that. I know they are not big turnout/events, so I don't think there is enough to lay down that much of a groove...
Also if anyone has a VTA setup with the same chassis that would be great to.
#7790
Narrow Chassie
I just got the narrow chassie from TOP. 95% together, but I can't figuer out how to tape down the batteries. Also I want to put holes in the shock caps do I just drill a 1mm hole on top of the plastic cap? PLEASE HELP
#7791
thank u bkspeedo big help gonna go run king of cal race and wanted to get som opinions where i shold be i am 86/54 right now and with track temp about 80f im coming off 6min. run at almost 160
#7794
#7796
#7799
It's not new, it was posted back before snowbirds in January, there is just a new batch.
I put te chassis on my car along with hanulecs setup from the 'c' with a few changes, and it is the first time I've driven a spool car that's not twitchy. I had been running a front gear diff for the last 6 months for it's consistency, but it wasn't on pace outdoors.
#7800
Luppi, here you go:
http://www.rctech.net/forum/9254207-post7744.html
There's no part number since it's EJ's own design. Need to call or email TOP Racing USA.
