T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 02-07-2011, 12:25 AM
  #6991
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Originally Posted by DaveW
I blew out another ball diff in the rear... any suggestions for fluid in a rear uPro?
Nothing beats the spec-r gear diff. I think the BD5 spec-r fits the photon with a few shims.
The Upro diffs suck. I have gone through 3 of them. And im sure you saw Tony shred his yesterday.
Jamison R is offline
Old 02-07-2011, 02:37 AM
  #6992
Final Stage RC-Photon LiPo chassis set(ProtoType)
New version motor mount will be red...
Seeking distributors...
Attached Thumbnails T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-fs01.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-fs02.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-fs03.jpg   T.O.P. Racing "Photon" 1/10 EP Touring Car-photon-fs04.jpg
JoJiAuE is offline
Old 02-07-2011, 04:07 AM
  #6993
smilekt's Avatar
Trader Rating: 13 (100%+)
nice ...
smilekt is offline
Old 02-07-2011, 07:04 AM
  #6994
DaveW's Avatar
I hear good things about the Spec-R. I did see Tony's ripped up, but i think it was probably due for a rebuild. Mine is too new to know of its durability...but it was butter smooth yesterday with no problems... not even a leak or seepage.
Ill see if a local has a spare i can try to see if its even worth shelling out the coin for a second gear diff...
DaveW is offline
Old 02-07-2011, 07:12 AM
  #6995
Dave, Mine hasnt leaked either but when I pulled it out to change the fluid in it, it is feeling pretty notchy and rough. I haven't run boosted with it either so I am not sure about this u pro diff anymore. Need to inspect it and go from there.
devilsquid is offline
Old 02-07-2011, 07:34 AM
  #6996
kschu's Avatar
Trader Rating: 16 (100%+)
i ran top photon gdiff before..it's so rough...then i switch to spec-r , it's butter smooth...but it's does leak alittle though
Roche released Spool v2 for TOp Photon. (spool cup made from spring steel)
kschu is offline
Old 02-07-2011, 07:52 AM
  #6997
dag32's Avatar
Trader Rating: 112 (100%+)
I just bought a Photon and will start building it this week. I also bought a BD5 Spec-R gear diff too, what size and approximately how many shims will I need for a good fit? Also what is a good starting point for the diff fluid? I will be running 17.5 no boost, rubber tire asphalt, medium size track.
dag32 is offline
Old 02-07-2011, 07:55 AM
  #6998
If you are running it up front out doors on asphalt my understanding is 120k is a good starting point.
Old 02-07-2011, 08:00 AM
  #6999
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
How thick is the chassis?
OVA is offline
Old 02-07-2011, 08:06 AM
  #7000
dag32's Avatar
How about running it in the rear, indoors?
dag32 is offline
Old 02-07-2011, 08:21 AM
  #7001
indoors rear I would start at 2k depending on traction outdoors on asphalt I think I would start at about 10k and adjust from there.
Old 02-07-2011, 09:26 AM
  #7002
Luppi Stefano's Avatar
wow good project!
but I hate the cut under the motor...why this choice?
Luppi Stefano is offline
Old 02-07-2011, 09:28 AM
  #7003
2.4mm
JoJiAuE is offline
Old 02-07-2011, 09:33 AM
  #7004
smoke81's Avatar
If your going to buy gear diffs.. I would go ahead and spend the few extra bucks and buy the Real Yokomo Gear diff.
smoke81 is offline
Old 02-07-2011, 09:39 AM
  #7005
Originally Posted by Luppi Stefano
wow good project!
lower the center of gravity...
0.5mm lower than the original motor mount.
JoJiAuE is offline
