T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 02-25-2010, 10:30 PM
  #3736
smilekt's Avatar
Trader Rating: 13 (100%+)
any one using other version of rear lower arm ? like top arp version on photon ?
smilekt is offline
Old 02-26-2010, 08:17 AM
  #3737
I tried Xray front arms and they fit but they are a bit more to the back.
I didn't had down stops bud it worked quit good.
Without down stops the car is almost impossible to drive. Chicanes work great bud normal corners is a disaster.
mikky32 is offline
Old 02-26-2010, 09:16 AM
  #3738
sosidge's Avatar
Why do you ask?
The old ARP/Scythe/HPI arms won't be a direct fit because the hinge pins are different, although you should be able fit the whole assembly onto the rear (arms, hubs, roll-bar links, maybe you would need to change the driveshafts too). The old parts have a slightly different geometry on the outer camber link and a different offset for the wheelbase which you should be able to take up with spacers.
You should also be able to swap the old parts onto the front in the same manner, the geometry is the same apart from the offset wheelbase.
But the Photon parts are very robust.
sosidge is offline
Old 02-26-2010, 02:08 PM
  #3739
pmc
Hello
I have a friend who wants to give me a set of springs from the scythe.
Wish is the diference of the Top scythe springs to the Top Photon springs?
The springs of scythe fit in the photon shocks?
Thanks in advance
Best regards:
Pedro Silva
pmc is offline
Old 02-26-2010, 02:42 PM
  #3740
Originally Posted by pmc
Hello
Thanks in advance
Best regards:
Pedro Silva
I use now also the Scythe springs. They are a bit shorter but fit very good.
mikky32 is offline
Old 03-01-2010, 01:42 AM
  #3741
*SBH*'s Avatar
Default Another win for Photon
TQ and win at the 5th round of the Danish Championships yesterday.
The track was super cool with a nice flow, and the car was awesome
2 out of 2 possible after the change to T.O.P.
Soeren Boy Holst
Denmark
*SBH* is offline
Old 03-01-2010, 03:49 AM
  #3742
stiltskin's Avatar
Trader Rating: 103 (100%+)
Soeren Boy Holst
Denmark
Congratulations. Keep it going.
stiltskin is offline
Old 03-01-2010, 04:36 PM
  #3743
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by P2
Here is his Reedy setup. He's now using 324 front springs and 1.2mm hole pistons.
He's fast on the track.....but slow on the internet
With that set up there you posted...is it me or is the belt pretty tight with whats on the sheet there?
vr6cj is offline
Old 03-01-2010, 06:58 PM
  #3744
P2
P2's Avatar
Trader Rating: 15 (100%+)
Belt tension depends on what condition your belts are in, some are looser than others. Even is the loosest setting, I find that the front white LF belt is still too tight. I have since switched to the stock belts since I can get them more "free".
P2 is offline
Old 03-01-2010, 07:11 PM
  #3745
vr6cj's Avatar
Belt tension depends on what condition your belts are in, some are looser than others. Even is the loosest setting, I find that the front white LF belt is still to tight. I have since switched to the stock belts since I can get them more "free".
Ok, got it. My first Top car and photon so was just following the set up but mine are tight like rubber band with those settings he has. Will adjust according. thanks
vr6cj is offline
Old 03-01-2010, 07:22 PM
  #3746
macdude's Avatar
Just putting the car together. Does TOP make a spacer kit? I see on the TOP usa site that you buy different size spacers but there doesn't seem to be kit that has several (4-8) of each size.
macdude is offline
Old 03-02-2010, 01:52 AM
  #3747
LOW ET's Avatar
Trader Rating: 109 (100%+)
spacers for what?
LOW ET is offline
Old 03-02-2010, 06:53 AM
  #3748
smoke81's Avatar
Originally Posted by LOW ET
spacers for what?
Spacers to adjust most of the stuff on the car. Camber link angle, wheel base, car width, etc etc.
I don't know off hand of any kit, but I would agree it would be a pretty cool idea.
smoke81 is offline
Old 03-02-2010, 07:38 AM
  #3749
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Yes, get the "TC-PSUS01". Its in the back of the manual under "Suspension".
mrrcguy is offline
Old 03-02-2010, 07:58 AM
  #3750
sosidge's Avatar
That one is only for the toe-in, it has a selection of 0.4mm/0.8mm/1mm/2mm large diameter spacers.
If you want to do camber links, wheelbase etc. they only come in individual sets. I've been combining the 0.5, 1mm and 2mm sets and that has covered me for every adjustment I've needed.
Of course, if you are not fussy about colour, other brands do sets with multiple sizes!
sosidge is offline
