T.O.P. Racing "Photon" 1/10 EP Touring Car
#2311
Not sure how that helps him?
Shock Spring (14 x 1.5 x 6.00) 344gf/mm , 19.2lb/in - Rubber Spec. Std
Shock Spring (14 x 1.5 x 6.50) 306gf/mm , 17.1lb/in - Rubber Spec. Std
Shock Spring (13 x 1.7 x 6.75) 560gf/mm , 31.3lb/in - Foam Spec. Std
Shock Spring (13 x 1.4 x 6.25) 306gf/mm , 17.1lb/in - Foam Spec. Std
#2312
Well, It's been four months now and still no second run Photon. I'm beginning to wonder if it coming at all. I know that a few people here changed their minds about getting one just because of the snow job, smoke and mirrors man...
If I hadn't already gotten some hop ups for the car I just might have forgotten about my order as well.
#2315
Leave your tripe on the desk at home punk...
Don't even start with me. I dare you put your money where your mouth is!
You assume an awful lot too. Come up here when your home floods or your local track gets washed away so we have more victims to annihilate on the track. BRING IT !
#2316
......................................__.......... ......................................
.............................,-~*`¯lllllll`*~,................................... .......
.......................,-~*`lllllllllllllllllllllllllll¯`*-,....................................
..................,-~*llllllllllllllllllllllllllllllllllllllllllll*-,..................................
...............,-*lllllllllllllllllllllllllllllllllllllllllllllllll lllll..................................
.............;*`lllllllllllllllllllllllllll,-~*~-,llllllllllllllllllll............................. ...
..............lllllllllllllllllllllllllll/.........;;;;llllllllllll,-`~-,...........................
...............lllllllllllllllllllll,-*...........`~-~-,...(.(¯`*,`,..........................
................llllllllllll,-~*.....................)_-..*`*;..)..........................
......................f`-,.........`-,/...*-,___,,-~*....,-*......|...`-,..................
#2317
#2318
Super Moderator
(Im sorry guys i thought giving him time off would help, I guess I will try again.)
#2319
What is the big difference in driving with the diff cone washers like this ((((((, contra driving them like this ()()()
And are any of you using other diff balls than the standard ones?
#2320
(((( will give a more instant diff response, sort of like running more tension in the diff, usually better for higher traction also seems to make the diff adjustment finer and harder to set
()()() will give some give and let it slip easier like running a softer diff spring. usuall low traction
i usually run some varation of the two above.
use the ceramic balls in the diff and the thrust much better.
#2321
I prefer this one lol
