fantom stock motor
I just got 4 from my LHS. I try to support them always. I have raced at 3 tracks that closed down in VA. I'm trying to keep the ones in NY open.
According to my wife I'm doing a good job
Cory
Cory
lmao.Good to hear cory.Yea actually if you have your shop order it and they sell fantom they should also be able to order a limited from the distributor being they cost the distributor or dealer a couple extra dollars.
Good news on hearing you support your local shop.Everyone should within reason.
Goodluck racing.
Goodluck racing.
Thanks, Same to you!
Cory
Cory
#21
Yea, There were 5. I left one!
You must have gotten the one with 59 watts, right???
C-Ya Friday
Cory
C-Ya Friday
Cory
#23
C-Ya Friday
Cory
C-Ya Friday
Cory
im not sure about friday cuz lee has to work. i guess ill ask my other friend to drive me if he has time.
#24
hey cory, good run tonight! after racing with the current esc im running in at the beginning of this season, i realized that the current limiter was set at medium and why my corner speed is so slow! i gotta try it out next week and see if it made any difference
#25
Don't you love all the little things that can go wrong!
See you on Friday.
Cory
See you on Friday.
Cory
#26
I have a Fantom stock motor and i personally dont like it. They work really good for the first few runs then they start to go down hill.
#28
Well i dont if its something wrong with mine or not but when i went to a on-road race not to long ago i got it cut and replaced the brushes (broke it in) just before and used it for 3 qual. and and it was in the middle of the pack for speed down the straight but after the 3rd qual. it was slow. I switched my motor to a green machine and it was the fastest.
#29
aeraccer-What can is the fantom motor?Meaning is it Yokomo,Epic?What color is the fantom?
What brushes did you PUT BACK INTO The fantom.
Reason for asking?
If you used a different brush then it isnt a fantom anymore.It's a fantom motor that YOU changed.
The motor could have overheated with the brushes you chose being onroad is kinda hard on motor's anyway and the brushes you installed didnt like it.NOT the motor.
So you say you replace the FANTOM motor with a Green Machine which is a RPM based motor.
Again I ask.Which Fantom were you using?
Reason for asking?
#30
aeracer: Well, I don't like to hear that someone is unsatisfied with the perfromance of one of our motors. I have worked at Fantom now for about 3 months. We build all the motors with Red Springs and F315 (767) brushes to keep it simple. I am sure since you race a lot of stock you are putting in the best brushes around.
I really wouldn't recommend going lighter than Red springs for 6 cell stuff. You could use a green on the negative, which will increase your bottom end. Stock motors are too finicky.
Another possibility, believe or not is you could have gotten a bad set of brushes. Brushes are mixed in big batches and then molded into the shape. If for some reason the brush didn't receive a balance of the mixture, then that would severely hinder the performance.
Either way, let me know and I will try to reply. Thanks, and good luck.
Jeff
Jeff
