8X8 or 6X6 EMAXX
8X8 or 6X6 EMAXX
I really want an emaxx. But not just any emaxx, i want the ultimate emaxx. Your donation of stuff and knowledge would greatly be appreciated. I plan for this one to be the ultimate basher: locked diffs, all wheel steering, maybe brushless, or the Kershaw design 900 brushed motors. Beggars cant be choosers. This is gonna have to be a group effort, because all ive got is a will to drive.
Go for it. Being different is a good way to get people interested in the hobby
So you wanna make an AWD E-Maxx, eh? Might be able to help ya out...
I've seen a 6 wheeler in action on the track. Quite clumsy on the track, however it is quite comical as it resembles a caterpillar wiggling along.
It does require some tweaking on the setup to get one to handle, mostly stiffening the front suspension and messing with the center & rear toe. Definitely not a race truck
haha, i wouldnt race it. . i would just go crazy bashing it .
is was thinking that it would look like one of those 8X8 trial trucks, maybe add dually style wheels?
OTE - that truck is SICK!!!! I live in a city so don't get to bash... I only really race, but man that is insane!
Without going into the full list, I'll give out the cliffnotes:
*6x6 Conversion from Hilltop R/C of Nashua, NH. Not sure if this place is still in business, I haven't been able to find their site for quite some time. I will say that this 6x6 kit is a lot simpler than a Gallimods E-MAX6X6; it consists of a 4mm aluminum lower skidplate, a 1-piece welded aluminum subframe that attaches to the center axle's bumper mounts and the rear axle's chassis mounts, and of course the key to a 6x6, the center differential case.
*Front brush guard is a combination of Traxxas aluminum bumper tubes (which you'll notice are now bent ) and a New Era Models front guard.
*Maximizer RageRing-equipped beadlocks on all 6 corners, holding firmly onto IMEX Claw Dawg tires. Makes the coolest noise sliding around on outdoor concrete, sounds like somebody's drifting a semi truck.
*Powertrain is a pair of 2nd-gen Traxxas Titan 23T 550 motors wired to a Novak Super Duty XR ESC, powered by a pair of TrakPower 4900mAh 2S1P LiPo packs
*Body comes from two Pro-Line 2004 Chevy Silverado's grafted together. The 6x6 kit recommended I use an R/C truck puller body by Parma but after seeing a picture of this narrow little light pickup with a big dumb engine sticking out of the hood, I went with the "road less traveled". Recently I discovered a crack in the right front fender...now I'm pissed.
*The prerunner rack/light bar was custom fabricated by RcBros.com. The guy that runs that site has a thing for scaler crawlers, and this rack was originally going to go on a Nissan Titan he was building. After mounting it up it looked a little gaudy, made the truck look REALLY top-heavy. He eventually decided to toss it and build another one, but I convinced him to pull it out of the scrapheap for me and after a PayPal transaction and a few days in the mail, now it sits on top of the Silverado Slammer. Not only do the lights work (there's a 9v stuck to the back window), but they WORK; in pitch black there's a good 3' long patch of "night into day" right in front of the truck and it'll simulate moonlight past about 40'.
OK enough of my bragging, back on topic
the powerplant i want to use is two mamba max systems. with 6 3 cell lipos. crazy awesome
That's probably going to split the trans in half
First time I ran LiPo in this truck was at the R/C Corral, a secret backyard track. The first thing out of my mouth when I came off the driver's stand was "Who needs brushless?!?"
Between the SD-XR speedo, the 2nd gen Titans, and the LiPos, my truck has more than enough power and speed.
I thought it was really cool when I found out if I took it up to WOT in 2nd gear then shifted back into 1st and slammed on the brakes, the whole rear axle would lift up about 2 inches off the ground and the center axle would start to wheelhop. Then I took 6 teeth off the 1st gearset idler
Check this out: http://www.dailymotion.com/search/hp...s28-trial_auto
