Ultimate touring car shocks
if i can remember right, HG makes some, i think there designed for hpi cars, but who cares, they might be good, because HG makes good stuff, just expensive, and light(wear).
HG only makes clear shock bodies which are no good (They discontinued them because the plastics weren't consistent)
I want better shocks mainly because of the tunability.
I like the idea of rotated a shock sfat to change the pistons for different track set up instead of rebuilding the shocks with new oil...
What do you think?
What do you think?
R/C Tech Elite Member
Any shock that has the adjustable piston that I've owned, I've figured out a way to go with a fixed piston because it's more precise. Why exactly are you wanting to do this? If you're expecting it to make the car faster, then I can tell you right now it wont live up to those expectations...
TRF Tamiya...
The Serpent shocks (which is what X-Ray uses) are pretty nice for tuning. I had several Serpent Nitro cars and the adjustability of the externally adjustable shocks was a very nice tuning aide.
Does anyone know if the X Ray shocks fit a TC3 and if they fit a LOSI XXXS-G+?
Being able to change dampening on the fly is a nice feature on my Xray and Serpent cars.
Calandra Racing makes them for the TC3. Has anyone tried them? I was thinking about getting a set for my NTC3.
Huge performance tuning option.
I think the vast majority of TC shacks are all about the same size. anybody's shock should fit on anybody's car.
Firstly, Xray doesn't use serpent shocks, they are very very similar but they are actually Xray units. I think Xray used the serpent units on their first T1 and then switched to making their own which are basically the same.
I run the serpent adjustables, very nice and they last quite a while between rebuilds. Being able to change pistons in a few seconds is a great option but they arn't really necessary unless you change tracks and conditions, week in, week out. If you race at one track, once you get your shock setup which will take all of a day's testing your pretty much set for as long as you race at that track. If your going to upgrade you might as well buy the best, tamiya TRF units.
Just my take...
Just my take...
my shocks my trf414mII are getting tight
i can barley adjust the ride height anymore....... i need to squeeze it really really hard...............
any ways to looosen it up again
Trader Rating: 22 (100%+)
the adjustable xray shocks are the way to go. built correctly they wont leak at all. if they leak you havent built them right. it would be to annoying to have to change the shock piston each time you wanted to change the dampening. (messy silicon oil sticks to your hands like brake fluid )
i heard that the O-ring will just 'enlarge' after u used for a long time and have a tight feel.
