New shock absorber coming from the US.
#291
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
It was funny when Tex showed them to me oh... 6 months ago. He handed me all the parts (for prototypes) and I didn't "get it." I was thinking "wtf are the little metal things for?" (not realizing they were magnets...) until he showed me.
These shocks are freakin' brilliant... and you can see a HUGE difference on the track. It allows you to run a much softer spring/shock combination without bottoming out in rough sections or "chassis slap" over big jumps. You can tell the difference watching how well the suspension "works" over rough sections without upsetting the car.
I'm definitely getting a set! I like to run a very soft setup anyway- this should help me a lot.
#292
I agree there has to be more to the shock than magnets that assist in bottoming out. If they let you run a softer spring/oil combo of course it will go through the rough stuff faster, and of course the magnets will help from bottoming out. But this will be at the expense of chassis roll and corner speed. I wonder how the shocks will compensate for that, there has to be some sort different valving or something. Time will tell.
#293
You actually don't lose any of the corner speed or roll. The magnets aren't super strength magnets that don't let the shock do its work. These just help keep all 4 tires on the ground no matter what.
Watching them go thru ruts and bumps is amazing. The chassis stays level and consistant while you can literally see the shocks compressing and rebounding so fast keeping the tire down and allowing you to keep as much traction as possible.
#294
#295
I agree, I wasn't saying the shocks don't work, they very well might keep the same corner speed. I was saying there must more to the shocks other than magnets. There must be some special valving/pistons or something else to complement them. If they were magnets alone, I would have reservations on whether this would work as advertised.
#296
20 pages on these things!!!!
#297
Independantly controlled compression dampening.
Independantly controlled rebound dampening.
Adjustable air pack.
I can visualize different strengths of magnets above and below the piston. Combine this with adjustable air pack and the shocks should be pretty adjustable.
#299
WHEN?!?!?!?
When are we going to be able to buy these shocks?????
#300
Christmas here and gone. No Magno shocks. Bummer.
