Traxxas Slash Setup
What size motor do you have? Is it the stock brushed motor? Also, are you wanting a basis for a setup such as shock angles, toe, camber, and tires?
Which version do you have? The Short Course or the Slayer Pro?
Short course is 2wd (electric) and other one is 4wd (nitro) and cost a good bit more!
Where do you plan running it vstrok?
Oh yeah I am in the electric only section of the forums haha
I wouldn't full with your stock setup if your not going to be on the race track
you would have to replace your stock speed control and motor and get a brushless esc and motor.
also go with a lipo battery... depending on 2 or 3 cell is how fast you want to go.. 2 cell is 7.4 v and 3 cell is 11.1 v... Most of the 60 or 70 mph slashes you see in youtube are running 3cell or higher... and you can expect run times depending on how thottle happy you are and what capacity of battery you run... the higher the capacity the longer the run time..
just to give you an idea i run a stock slash with the brushless combo i was talking about and a 2 cell 2500mah lipo and get on average of 20 minutes... thats average ... ive gotten 30 minutes and as low as 16 when i was really on the throttle...
