8b and 8t cvd's
8b and 8t cvd's
ok i bought this losi 8t and getting back into racing so i feel like a noob sometimes but heres the deal,the left front cvd does barely reach the out drives,in fact if you drove this thing the outdrives would get chewed havent driven it lol,the guy i got it from also ran a 8b im thinking its the wrong cvd cuz everything else looks normal
The 8B cvd is 29mm shorter than the 8T, if it is barely reaching the out drive, check the hinge pin for damage, also the retainers and arm for wear. Set the camber at least 1 degree neg.
You should also check that the droop is set the same on both sides.
ok i feel like such a noob and frustrated lol anyways the cvd on the left is what i pulled from my truck that barely reaches the end of the out drives,so thinking it was a buggy shaft i ordered off umm ebay what was said to be cvds for an 8t,what i got is what you see on the right in the photo,obviously much shorter than the one thats short allready someone,anyone helllllppppp,what am i doing wrong
Could be the front center cvd you ordered, or a buggy wheel cvd.
Thats interesting. I would first measure camber and make sure they are even left to right. I would then set the droop(shock length) and recheck your driveshaft location. Mine are close to the edges, but they more resemble your rightside CVD, ie, the left outdrive looking at the pic. If that doesnt help, carefully examine the components on the front left arm. Make sure your bearings are good and everything is seated right. After that if it is not similar to your other side, i would suspect an incorrect cvd installed.
The pictures don't show what is going on with the front end. Have you taken both of the front dogbones out and put them side by side to see if they are the same?? If they are the same, and the droop and camber are set the same they should be seated the same. Did you buy it second hand?? I wonder if it is possible that someone found one from another manufacturer that was almost the right length and just put it in to sell it?? I see your dilemma but without more info and more detailed pics it is just a guessing game.
Last edited by BOOST; 03-04-2009 at 07:44 PM. Reason: ok jut re-read your first post and it is indeed second hand.
Chances are there is a rear/center bone installed on the left front suspension. The rear/center bone is just a few mms shorter than the wheel drive bones.
Rear center bone is 122mm from center pin to center pin.
Wheel drive bone is 125mm from center pin to center pin.
3mm is about what it looks like in your picture.
