Official GRP .21 non-tuned off road buggy engine thread!
#76
Ya ok, So I am ordering the clutch bell and some gold springs tonight and I will loctite everything up tight and if its warmer this saturday I will try and get my dad to take me again. Also now I have a problem, I cant get my clutch bell off??? Why would this be and how do I get it off? Should I heat the clutch bell?
#77
re
ok will it spin freely?if it does then you could try heating it.if it doesnt spin freely something in your clutch might have come loose then do what you have too is the best I can tell ya without seeing it
#78
Try 2 different kind of springs. Right now I have 4 maxlife shoes with green and gold springs. They work really good. See the screw right on top of the cb bearing? Well get a vise or something like that to lock the flywheel down and get yuor 5/64" hex wrench and try to loosen it. If worse comes to worse, I guess you could heat it.
#79
ya everything spins freely so I think I will try heating tomorrow
#80
Began break in today. Preheated with a $20 heat gun from homedepot to 160-180 degrees. Ran 5 tanks at idle on the starter box. Had to increase the idle and LSN 1/4 turn for the first tank to get it to idle. With foil on the head temps were between 185 and 195 the whole time. Put it on the track and frequently gave it 25% throttle bursts. Temp got to 212.
Richened up the top and bottom ends 1/4 turn (which means the LSN is back to factory setting) and ran two more tanks giving frequent 25% throttle bursts...temp was 160. Very little smoke which concerned me. Richened up the top a 1/2 turn checking for smoke...still very little. Richened it another 1/2 turn. It was so rich it barely ran (went 20 ft and back)...but still little smoke. Put HSN back in 1 full turn so now its 1/4 turn richer than it was out of the box and called it a day. 8 Tanks total.
PS...I'm using O'donnell 30%
Any advice?
Any advice?
#82
Thanks for the info on the smoke John. I leaned out the HSN 1/4 turn and saw more smoke, more on bottom than top. Ran full throttle bursts on tank 11temp was 175. Put it on the track for tank 12 and temp got to 217 running slightly rich (felt like it was rich on bottom, good on top). Richened up the HSN 1/4 and leaned out the bottom 2hrs for tanks 13 and 14. With that setting temps were 212 car feels fat on bottom, ok on top, with equal smoke throughout. Seems like if I were to tune to performance and smoke, temps would probably be 220...should I be concerned? Any advice appreciated
#83
Mine runs at 220ish. Oil content of the fuel can affect engine temps. I run 12% oil in my fuel. If you are running 10% or less your temps should come down a little. Then again there are many other factors involved. If it sounds good, runs good, and smokes good, it should be good.
#84
Hey guys, as me and toofless were discussing above about my clutch springs. He says to put the golds in but when I FINALLY got my clutch bell off I see that golds were in there. Could springs loose there snap? Should I put new golds in anyway and see what hapens?
#86
Dont be too concerned about the temp.
#87
ya I finnally got it off. I think I will change the springs anyway sinceI already ordered new ones.
