New Yokomo TC, the BD-5
#3646
I think it is a BD-302
#3647
BD-302FR1
BD-302FL1
this is the setup i run which have high speed and low speed steering
shock fr /rr oil - 500
ff 44.2mm toe block
fr 43.5mm toe block with 0.5mm shim underneath
inner camberlink 4mm, outer 0.5mm
ackerman 0mm
rf 2.0mm toe block
rr 45.7mm toe block with 0.5mm shim underneath
inner camber 4mm, outer 0mm
droop fr - 5
droop rr - 4
fr spring - Ride green
rr spring - hpi silver
Front sway bar - 1.4
rear sway bar - 1.2
lowerdeck - 2.3mm w/o hole, 2.5mm upperdeck
maybe this setup alittle weird but it work good for me...lol
BD-302FL1
ff 44.2mm toe block
ackerman 0mm
rf 2.0mm toe block
droop fr - 5
droop rr - 4
rear sway bar - 1.2
#3648
BD-302FR1
BD-302FL1
ff 44.2mm toe block
ackerman 0mm
rf 2.0mm toe block
droop fr - 5
droop rr - 4
rear sway bar - 1.2
BD-302FL1
ff 44.2mm toe block
ackerman 0mm
rf 2.0mm toe block
droop fr - 5
droop rr - 4
rear sway bar - 1.2
i was also thinking since most of the other yokomo drivers dont complain about understeer that much, that maybe it has to do with the body position. so i will check this at the next ETS race.
i should get more steering if i mount the body more forward right? dont wanna move only the wing a bit forward, cause this would take away too much rear grip. and the rear is a bit loose already.
#3649
hahah yes that even sounds strange to me...but maybe worth a try.
#3650
hi guys, i just built a new kit (wxi) and took it on the track yesterday. car works like a charm (like the other yoks ive built), but there is no steering like in the other ones.
steering only kicks in really, when at very low speeds. in every other situation power, off power etc. it just pushes real bad.
i use ride 32 tires (preglued, handout tires in club). i have attached the latest setup sheet.
glad if you guys had any pointers.
#3654
Have just seen that Yokomo is going to sell double joint shaft for rear
Some drivers ran it at the last ETS in Apeldoorn, like Hayato and Tam's Boys. But I can't imagine what they are supposed to give to the car? Ok, for the front, it decreases vibrations due to steering, but in the rear... Does anyone get an idea of what they bring for the car's behaviour?
Thanks for answering,
G-rem
Part no: #BD-010RW (YOKOMO DOUBLE JOINT UNIVERSAL SHAFT FOR BD5 REAR)
G-rem
#3655
G-rem
G-rem
#3656
G-rem
G-rem
Smoother shaft movement under suspention movement!
#3657
Thanks for your answer...
I've to admit that it makes me a bit doubtful about their real utility... I thought original CVD's shafts were ample
Does someone already try this? (I know they're very recent, but )
G-rem
G-rem
#3658
Im changing brands so all my BD5WX stuff is for sale.
http://www.rctech.net/forum/australi...l#post10904494
#3659
Hi guys
I'm new to the Yokomo brand. Just a quick question.
I noticed on the setup sheets that for low traction tracks you raise the RC by adding spacers to the camber link and lower the RC on high traction tracks.... So this correct? I thought its the other way around??
#3660
Hi guys
