New Yokomo TC, the BD-5 >
Old 11-28-2011, 01:33 PM
  #3286
cheers mate. Going to stick my gear diff in the rear and just found it was leaking! no luck at the minute!
retro_ryan is offline
Old 11-29-2011, 01:38 AM
  #3287
kschu's Avatar
Trader Rating: 16 (100%+)
change the oring and apply yokomo diff grease should solve your problem...
kschu is offline
Old 11-29-2011, 01:51 AM
  #3288
hacker's Avatar
Trader Rating: 141 (100%+)
Default WXI
does the wxi also include both carpet and asphalt chassis?
when is it out?
hacker is offline
Old 11-29-2011, 10:24 AM
  #3289
It's leaking from the outdrives anymore tips?
Old 11-29-2011, 11:18 AM
  #3290
caltek1's Avatar
Trader Rating: 38 (100%+)
retro_ryan,
As kschu suggested replace the o ring on the outdrives and either use the Yokomo black diff grease or use AE green slime. The o ring fit inside the gear diff and onto the out drive shaft. This seals the diff outdrives.
Regards,
Calvin.
caltek1 is offline
Old 11-29-2011, 12:08 PM
  #3291
cheers mate. i'll give that a try. Any recommendations on oil in the rear gear diff on carpet?
Old 11-29-2011, 04:52 PM
  #3292
kschu's Avatar
i just back from attending a carpet race last sunday...car was great, only driver nt good..
qualifying - dnf, 1st, 2nd,1st,1st
i unable to break the 3rd qualifying record due to some back marker..
but since it's took best of 1 round, so i took the 2nd spot in qualifying.
final was too hard as it's was too pack n hard to overtake..
overal finished 2nd place.
i use 800wt in the geardiff..so far so good.
kschu is offline
Old 11-29-2011, 06:16 PM
  #3293
rai
chu, mind sharing your set up for our stadium asphalt track? Thanks chu
rai is offline
Old 11-30-2011, 02:42 PM
  #3294
Trader Rating: 26 (100%+)
Anyone know where there's any bd5wx in stock.
eddie10 is offline
Old 11-30-2011, 03:47 PM
  #3295
Hugh Jazz's Avatar
Last time I looked KShobby.com had one in stock.
Hugh Jazz is offline
Old 11-30-2011, 04:16 PM
  #3296
A Ilievski's Avatar
Trader Rating: 39 (100%+)
They are out of stock now. If you send them an email im sure they can get them in asap though.
A Ilievski is offline
Old 12-01-2011, 05:59 PM
  #3297
kschu's Avatar
should be coming in , in 2 week times.
kschu is offline
Old 12-01-2011, 06:01 PM
  #3298
kschu's Avatar
droop front 6, rear 5
front hpi pink, rear hpi silver
front 500k geardiff oil
rear 1000 geardiff oil
front 2mm shim for inner camberlink
rear 1mm shim for inner camberlink
shock oil 600 front and rear
front camber -2, rear -2
front toe out 2
front right height 5.5, rear 6
bodyshel spec-r m6.
i dont know it's a good setup or not...
kschu is offline
Old 12-01-2011, 07:14 PM
  #3299
defcone's Avatar
Trader Rating: 15 (100%+)
front toe out 2
bodyshel spec-r m6.
Bad setup, good driver XD
defcone is offline
Old 12-02-2011, 08:27 AM
  #3300
fpart's Avatar
Trader Rating: 41 (100%+)
I think the new BD5 is called the WXC. Is the the version that will be available in a couple weeks?
File Type: pdf
fpart is offline
