New Yokomo TC, the BD-5
#3091
anyone has an idea which other diff blades would fit on to the bd5 for both gear diff and ball diff usage?? i find the yokomo ones wear out to fast.
also any ideas on how to use blades in front with the steel spool cups??
cheers
v
cheers
v
#3093
Spec-R make blades
Just finished building a WX for a friend, dont know why but this car feels and looks so much better than the previous models in the previous BD5 range (we have owned them all) The ballcups are simply AWESOME Might put some on my HB they are that good
#3095
#3096
I've ordered quite a number of Yokomo blades and the price still does not match the price for a new outdrives. But then again, the blades might fall off during the 5 mins run and might scarred the outdrives too. So the problem is unavoidable.
#3097
#3100
I use Spec-R blades, too, i run in mod, a friend give me 2 for test in last ETS, and worked very good, no problem in all weekend with it.
I find another solution for spool, with plastic outdrives, i put a alu reinforcement, and worked very well, exted the live of outdrives 4 times, work with Litemod cvs cardans, because the pin are small, for original yokomo cardans need to cut a litle the pins, for not blocking free movement.
Attached are a photo, i take with phone now.
Greetings, Luis C.
Greetings, Luis C.
#3103
Hi guys,
Running my WX at the local track and eventually small bit of the carbon from the chassis broke due to hard impact. However, there is no crack on the chassis. Is it ok or will it has an effect on the stiffness of the chassis? Sorry if the question has been asked before in other threads.
#3104
Greetings, Luis C.
Greetings, Luis C.
#3105
Hi guys,
