New Yokomo TC, the BD-5 >
Old 05-11-2011, 11:55 AM
  #3016
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Turbokisa
Ronald,
i have question about BD5 shocks. What's the difference beetwen black and transparent bladders? And beetwen single/double o-ring sealing?
Transparent ones are softer than the black ones and apparently you had to replace them everytime you rebuilt the shock. From another thread(something along the lines of): "two o rings creates a heavier dampening effect"
defcone is offline
Old 05-11-2011, 02:54 PM
  #3017
yeah the problem of the transparent ones is that they sometimes swelling. and the black one is slightly harder.
two o-rings doenst fell so smooth to me on the track most of time when I tried them
R.Völker is offline
Old 05-11-2011, 03:46 PM
  #3018
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
In regards to the foam cushion inside the shocks on top of the bladder, is there any reason why people leave them out sometimes?
VintageFrog1 is offline
Old 05-11-2011, 04:53 PM
  #3019
housey's Avatar
Pretty sure its 'cos they make it difficult to obtain little to zero rebound.
housey is offline
Old 05-19-2011, 06:27 AM
  #3020
Turbokisa's Avatar
Hi Ronald,
do you use suspension ball joints as is or reduce excess play?
I found that in BD5 it's a little bit more compare to others chassis.
Turbokisa is offline
Old 05-19-2011, 07:12 AM
  #3021
defcone's Avatar
Hi Ronald,
I found suspension binds when u try to take out play, but I took out steering up until there was only a tiny bit of play left and the car felt better and more consistent to drive.
defcone is offline
Old 05-19-2011, 07:20 AM
  #3022
Jochim_18's Avatar
Yokomo cars tend to have a lot more play than the others but it does not affect the handling of the car at all.
Jochim_18 is offline
Old 05-19-2011, 07:40 AM
  #3023
defcone's Avatar
shhhh speed secret!!!
defcone is offline
Old 05-19-2011, 07:42 AM
  #3024
kschu's Avatar
Trader Rating: 16 (100%+)
the new ball cup that come with WX is much better...
kschu is offline
Old 05-20-2011, 05:35 AM
  #3025
rai
It's true, with the WX the play is much lesser compared to the previous BD and other cars.
rai is offline
Old 05-23-2011, 07:40 AM
  #3026
hi, ronald and everyone~
Recently, I try the top solaris tire (hard compound),compared with sorex tire,
the tire feel a understeer in mid-corner(low & high speed ) and slower response...
how can i solve these problems..? could you mind provide any suggestion for me~?
thankyou!!!!:
here is my setup:
track temp: around 4x, indoor asphalt track(Hong Kong TRC track, do u remember?)
lower deck: WX chassis
front gear diff: kyosho 500,000
rear gear diff: kyosho1,000
tire treatment: FXII
motor: 4.5r
Body: Speed6(Lightweight)
the track:
teamsanwa is offline
Old 05-23-2011, 07:44 AM
  #3027
kschu's Avatar
Originally Posted by teamsanwa
hi, ronald~
Recently, I try the top solaris tire (hard compound) on high grip asphalt track,
compared with sorex tire, thes tire feel a understeer in mid-corner and slower response...
thankyou!!!!
here is my setup:
track temp: around 4x, indoor asphalt track..
motor: 4.5r
[IMG][/IMG]
maybe u can try LTC-R bodyshell, remove the 2mm bumpsteer, move forward your front wheelbase. use hpi pink spring infront
kschu is offline
Old 05-23-2011, 11:30 AM
  #3028
part-time racer's Avatar
hi, ronald~
thankyou!!!!:
here is my setup:
motor: 4.5r
the track behind you
I dont run a bd, but i would remove the front gear diff and run a spool. ?
part-time racer is offline
Old 05-23-2011, 12:52 PM
  #3029
I´m not Ronald, but my setup is identical from your, with only a minor change in rear RC, i put 1 mm in and 0.5 out ( in camber link) or 2 - 0.5, when i need to react quicker i put a yokomo springs Green - pink, sometimes a litle thin oil.
In bumpsteer i always use 0 mm.
Greetings, Luis C.
luic is offline
Old 05-24-2011, 04:05 AM
  #3030
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Try 0.5-1mm ackerman shims, and definatly remove front gear diff and bump steer
Yokomo_Ant3 is offline
