New Yokomo TC, the BD-5 >
Old 03-18-2011, 09:31 AM
  #2806
no servo mount hole for both the post?
ddd2k is offline
Old 03-18-2011, 10:56 PM
  #2807
Trader Rating: 23 (100%+)
No, only the inner post is used on the W.
pcar951 is offline
Old 03-19-2011, 12:58 AM
  #2808
Nico''s Avatar
and with double side tape where is absolutely no worry about that.
Just use a good double side tape, I use Plasto tape which can resist to 50 kg and which is made with something such latex inside instead of foam so you can tear out this tape.
I also add a point a glue to secure more and the side of the servo.
One day I wanted to change my servo and I needed half an hour to put it off so it is very secure!
Nico' is offline
Old 03-19-2011, 01:04 AM
  #2809
defcone's Avatar
Trader Rating: 15 (100%+)
I used shoe goo and when I had to switch servos, it actually wasn't hard. As the shoe goo dries and is strengthened, but also not very hard to clean up after removing the servo.
defcone is offline
Old 03-19-2011, 01:06 AM
  #2810
=FLIP='s Avatar
Trader Rating: 24 (100%+)
dont listen to this defcon fellow he is a spamaholic
=FLIP= is offline
Old 03-19-2011, 01:30 AM
  #2811
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Yokomo_Ant3 is offline
Old 03-19-2011, 02:09 AM
  #2812
kschu's Avatar
Trader Rating: 16 (100%+)
i use shoe goo to stick down my servo to the lowerdeck...
kschu is offline
Old 03-19-2011, 08:24 AM
  #2813
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
I use shoe goo also. I have never had a problem with it and was also able to remove the servo to change chassis.
Shopkeeper is offline
Old 03-19-2011, 08:27 AM
  #2814
bukil's Avatar
Trader Rating: 39 (100%+)
What are you doing up so early, Mr. Fast dude?
bukil is offline
Old 03-19-2011, 08:39 AM
  #2815
I use shoe goo as well, but since he made a chassis it would be nice to fix that missing mounting hole.
ddd2k is offline
Old 03-19-2011, 11:44 AM
  #2816
Shopkeeper's Avatar
HAHA, What about you??????????? Mr. out till 4:00 am!
Old 03-20-2011, 11:22 PM
  #2817
Trader Rating: 12 (100%+)
Where can i find some volker setup sheets?
dex410usa is offline
Old 03-20-2011, 11:38 PM
  #2818
Nico''s Avatar
here: http://www.petitrc.com/reglages/yoko...YokomoBD5.html
Nico' is offline
Old 03-22-2011, 02:39 AM
  #2819
jackdani's Avatar
hi guys!
last month i had my first race with my bd5wr and i have to tell you i was very impressed.
i ran with the "flex" chassis and the ball diff as it was on asphalt and the grip was poor.
i managed to improve almost 1 sec. over my record and i am very happy and satisfyed about the car.
but i m trying to test all the components of the kit, that is why this coming sunday i will race with the normal chassis...the car is allready set..and i did this choise even because the weather is becoming pretty hot...and the grip on the asphalt will be much better than last time.
i would even try the gear diff...which should be really good, as anyone told me.
my question however concern the chassis:
did someone compare the two chassis on the same surface, asphalt and carpet?
if yes which one do you prefer and why?
bye
jackdani is offline
Old 03-22-2011, 04:42 AM
  #2820
defcone's Avatar
Originally Posted by jackdani
hi guys!
bye
If you have a look at Ronald Volker's results, most asphalt races he won were with wr chassis (Jap nats, outdoor euros) and carpet races with the w chassis.
defcone is offline
