B4 grinds a little when taking off sometimes...
I'm running a 10.5 LRP Eraser/LRP AI combo, Venom 7.4 lipo, and my gearing is 24/81 (I think the spur is 81, whatever comes with the FT kit) I notice when I take off, sometimes I hear a slight grinding sound, it ONLY does it when taking off from a dead stop. If my gear mesh was too tight, it would do it all the time, right? What could it be if not that?
it is either your gear mesh or diff
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
If everything in the drive train is free and in good shape. Make sure your motor timing is not too high, either on the motor or ESC. When you run brushless motor timing too high the motor will cog. This cogging will sound very much like gears grinding. Hope this helps.
A ha! It's the simple things we never think about giving us the most problems. Glad too see the problem is fixed.
i had a grinding issue thes weekend to. mine ended up being my diff was to tight and seized. i ate right through the rings and ruined a few carbide balls. i choked it up to a learning experience. i am used to gear diffs
check gear mesh, diff, and slipper.
