Proline 1/10 Buggy Tires, WTH?
Dont think I would say that they dont care about 10th scale. They must care a little. There is the new Suburb tire coming out which is a blue groove tire (which they havent had) Sure, it looks alot like the Losi BK Bar (even the JConcepts tire uses the same conceptual design) but at least they have a new tire for 10th coming out. And it is a new rubber compund. Not the same as the stuff they've been using, definately has a different feel to it. And you cant go wrong with the A-main results at the Nats, they obvoiusly work. I wouldnt be suprised if Proline is working on revamping the 10th lineup a little bit. Just a change in compunds and foam could really help their current offerings.
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
It would be quite nice if they changed their foam for sure.It sucks spending 12.00 on a set of buggy rears just to have to spend another 5.00 for foams that dont suck.Honestly their foams are like the worst out there out of the top 4 tire manufacturers.
+1!!! the same pair of slicks will last you a good while though
#20
R/C Tech Elite Member
From what I was told from a Pro-Line driver, there is a good chance there will be 2 new hard packed blue/black groove tires coming out. One is the Suburb, as mentioned above, and then another that is a variation of the Suburb/BKBar design. They will be available for 2wd, 4wd and truck in their new clay compound.
#21
I know,I have been looking for them to start including decent foam with their tires as the other manufacturers do.I mean even though the losi stock foams are a little on the soft side they dont disentigrate like the stock pro-lines do.
