problem with Tamiya DB-01 Durga (hex hub bs8)
helo
one of mi front wheel washer is broken!
is the item BS8 hex hub
my rc shop dont deliver this.
can you tell my is this fully compatlible with the part bs8 and works with the orig. wheels:
http://www.rcmart.com/catalog/rc-db0...h=595_744_1096
thx
cely
thx
cely
They look like they are made to fit larger (12mm?) hex wheels, like the DF03 or touring car size hex. I'm not certain, but that's what they appear to be.
I broke the kit hex (on my 501X though) and there are no other options that I know of apart from the proper Tamiya items that fit straight on. You can fit other similar small 'losi style' hex's - such as the HB d4, Yokomo BX, AE B44, Losi XX4 etc etc - but you will need to drill out the hole to 5mm I think in order to fit it over the axle.
I use HB D4 hex's on one car, B44 hexes on another and kit hexes on the third.
any plastic 12mm hex hub from a TC will work. Your LHS should have some around.
can i put on "normal" wheel hubs from a tamiya tc car and put on new wheels like this?
http://www.rcmart.com/catalog/rc-roa...l?cPath=35_959
and for the durga front wheels givs no other posibility as bs8 part from tamiya?
cely
cely
