How you clean your rides?
I googled it and found their homepage and ordered it direct. I think 2 cans shipped was just a little less than $24.
Maxima Racing Oils or SC1 ought to get you there.
I'm surprised Porkchop hasn't come on and told you to put it in the dishwasher yet!
#22
Does anybody use automotive break cleaner?
#23
I use break parts cleaner and the air compressor.
#24
I have a small parts cleaner tub and the hose has a brush on the end of it. Kinda Like this one but mine is a little longer.
I Just got it and it had kerosene already in it. The kerosene worked ok but it was not worth the smell. I filled it with WD40 and it works great. Cut my clean up time in half.
Someone mentioned earlier to use full strength simple green. I did that on a blue aluminum chassis and it took the blue off
#25
If you use brake cleaner...make sure its non chlorinated formula. I normally use diluted Simple Green for all my cleaning needs in the garage and on my R/C cars. Stuff works miracles on dirt and grease. Just make sure you dilute it with water because if you use it straight it will remove anodizing.
#26
now you tell me
#27
I'm just starting nitro racing this year so I havent ever really cleaned a rig. What do you guys think would be a good beginner way of doing it? I was thinking just to take my engine and radio tray out and hose it quickyly. Then towel dry and spray all hinges and bearings with a shot of Wd40. Will this work? Also will the screws on my kit rust because of this?
#29
Oh cool. So should I spray every screw with wd40?
#30
Just spray everything with WD40
