Hard wiring batterys
same here. I switched over already to hardwiring, and it's been good to me. I switched because i hated pullng apart tough connectors, so i just cut them off, and changed wire. I feel alittle more punch, alittle, very little, but it's there. I didn't change more power, i did it because of dislike of connectors, and the nicer look of everything.
Thats why i havnt allready switched its such a drag having to solder things all the time, especially as usually theres not a lot of time between races, when i go regional racing, (next sunday ) I would consider it if my packs werent all setup for corrallys.
I used to use plugs and they were a pain in the butt so I switched to soldering. It's much easier in my opinion, less wire clutter and less resitance, though I didn't feel any difference at all when I switched to hard wiring. It's all personal preference.
Corally connectors are very good. I find it hard to believe that pro3racer could actually feel a difference. And if he did, the connectors must have been in a really bad shape.
The best reason for hardwiring is that the connectors can't be unplugged in a racing accident.
i think that if you can crash hard enough to disconnect yor packou are doing somthing very wrong i have been racing for a long time and anything from mod to 540 and stupid stunts and i have never diconected a pack even in 1/12 when my pack flew out of the side of the car but it did not disconect and i did my last lap.
this is only my opinion so yeh corally or deans plug are the best way to go, corallys might have a slight margin on deans conectors
i said the difference was very small, but it was there, i feel a little more punch on starts, just a little. I feel the same as fatdoggy, it makes life easier, nothing to hang anywhere, such as a big plug. I never had a battery come unconnected, when my battery falls out, it takes my esc with it, and then hangs on by the motor wires. One bad rollover/cartwheel/t-bone, made it do that. It is just a personnal preferance, and an on/off switch cures the hurry up part, because i have my batteries in my car with about 15 minutes to spare, on average.
I agree with Airwide, all the numbers I've seen on the high quality connectors (Dean's, Corally, etc) show that the connectors do not add any measurable resistance to the battery/esc connection.
FWIW:
According to Dean's website "The Ultra Plug actually has less resistance, including the solder joints, than an equivalent length piece of 12 gauge wire"
FWIW:
how is that possible. With connectors, you have a total of 4 solder joints, and the metal in the connector, and without them, is 2 solder joints, no connector, but in it's place is about 1/2 inch of wire. Other wise it's all the same. So it doesn't equal, there is less resisitance in hard wireing, there is, there has to be with that infomation figuring. Plus, if solder bad, thats 4 bad solder joints, to 2, and after every race, you practice soldering them back on, so you'll get better, hehe.
As long as You have solder with rosin it will be fine.
The rosin will clean the surface and give you a better conection.
Assuming the person soldering the connectors is skilled, the amount of resistance added from a solder joint should be minimal. Also, I beleive the point that deans is making is that their connector (which is made out of a rigid conductor) has less resistance than stranded wire (which is flexible).
Of course there's only one way to prove anything conclusively, does anyone have an extremely sensitive multimeter?
i'll check my solder right now to see if rosin is in it, then we'll see if i'm gainin much, hehe
stupid me, i should have kept this in one message. , does 40 tin, 60 lead, rosin core sound good?
