1/8 scale brake setups?
how many of you run drag brake?
In nitro? IMO, drag brake would create an expensive clutch bill...at the very least.It would also put a strain on your T servo. Don't do it.
thanks. I will remove the drag. I liked it because it made jumping smoother and it dipped the nose every time i let off the gas and helped it rotate off power in the turns. I dont understand the clutch thing. My brakes only drag when i let off the gas. Under even min throttle, it has no drag at all.
IMO, would prolly cause heat and wear issue's in the long run!
