Lipo Question
Lipo Question
Hi,
I have a lipo question. I am trying to build a lipo discharger by using a resistor. but im trying to calculate how many ohms and watts i need the resistor. but im am confused on the C rating of the lipo pack. I know that the C rating is the safe amount of current used to discharge the Battery. For example, if you have a 6000mah lipo rated at 20C, you can safely draw 6000mah/1000 * 20C which is 120AMPs. this is where i am confused. 120AMPs IS A LOT. So, that means if my am using a 5S setup, the power consumptions discharging at 20c is P = V*I = 18.5v * 120A = 2,220 WATTS.... What the heck am I doing wrong here? My calculation is making ZERO since. Please help1!!
Why are you trying to discharge a lipo battery in the first place???
For one you don't need to apply a full 30C discharge to simply store your lipos. Secondly you should NEVER discharge a lipo without some form of cutoff. In this case you need something that can adjust the cutoff for 3.8volts a cell.
Sounds to me like you are a bit out of your depth...you are much more likely to damage your lipos fiddling about like this than you are storing them at 100%. Either don't charge them quite all the way before storing or run them a bit first. What kind of charger do you have? Doesn't it have discharge capability?
Have you checked out the Thunder Power TP-610C charger?
It has a discharge function, plus it has a 50% "storage" charge option. There are multiple failsafe features built in to prevent Lipo damage/balance problems. (Read; Idiot proofing.) It also charges up to 10amps! I think it's a great charger for it's $130 pricetag.
Teeforb - Your new ride is looking good. As for discharging lipos - as already said - I wouldn't bother. You're not even storing them that long - you'll be out racing in a week when this weather goes away right?
You're over thinking it. Just take the battery out of the car after the last race of the day and put it away. There's plenty of charge left in it after a race for storage. I have left my lipos partially charged in storage all summer with no ill effects.
I'm in the same deal, but with a 0610iNet charger - updating firmware does not add a real discharge function. I don't remember which update added it, but 0610iNet and the original DUO added a 300ma discharge capability and its only intent is for the storage/TCS function. If you specify a value thats less than your batt has, then the DUO/0610i will discharge at 300ma until it reaches appropriate voltage for the storage you specified.
The new DUO II and 0720iNet chargers have a true discharger with an 80watt discharge capability.
