NEW NOVAROSSI 2009 ENGINES
Old 07-15-2009, 09:47 AM
  #166
Originally Posted by itchy b
Does the 2652 pipe have the same effect on performance when used with the 08 353 as when used with the 09 compared to running the 2630?
I would say so. I have 2652 on my 353 09. Since 353 08 and 353 09 have the same port timing, 2652 should provide the same performance.
silverM3 is offline
Old 07-16-2009, 06:42 AM
  #167
itchy b's Avatar
Thanks M3!
Looks like i'll be getting one to try out soon then!
itchy b is offline
Old 07-16-2009, 07:26 AM
  #168
i am using the 2652 with my 353 08 and also 353 09... on both engines, the new pipe works flawlessly... i cant tell if there is any performance gain but the fuel consumption is noticeably better...
another plus point is that the pipe is bloody sturdy!
katze is offline
Old 07-17-2009, 01:10 PM
  #169
TORQUE ROD's Avatar
Cool
How many shimm does a 353 09 have? and how many shimm should you put in it when running a 20% nitro? thanks.
TORQUE ROD is offline
Old 07-17-2009, 06:02 PM
  #170
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Thumbs up
it should be shim for 16%....it has one silver shim which is .2, to shim it for 20% add .1 which is a copper shim....for 25-30% go with .2...that should work fine.
Ivan Dickson is offline
Old 07-20-2009, 11:18 PM
  #171
Thanks M3!
Just bought another 2652 and 353 09. Now I am waiting for my 733 to come
http://www.rc-toro.com/product_info....70fc3409ad7a9c
silverM3 is offline
Old 07-21-2009, 08:19 PM
  #172
TORQUE ROD's Avatar
Cool
Ivan,
Thanks for the info about the shimms..
Old 07-21-2009, 08:52 PM
  #173
Thumbs up
Ivan,
no problem...glad i was able to help.
Old 07-26-2009, 02:49 PM
  #174
musti72's Avatar
I realized that there is no black crankcase under the purple cooling heads of Novarossi 353'09 on the pictures...They are like 353'08 version crankcase. Anyone knows anything about it?
musti72 is offline
Old 08-11-2009, 03:09 AM
  #175
Roelof's Avatar
I have seen the new offroad Toro Nero engine has a different bore/stroke specs (15.88mm x 17.60mm) and from what I have heard some teamdrivers are driving with an onroad version with these specs, anyone knows more?
Roelof is offline
Old 08-12-2009, 06:48 AM
  #176
itchy b's Avatar
My 09 353 has a black crank case
Maybe the pics had a pre production motor?
itchy b is offline
Old 08-19-2009, 03:41 AM
  #177
aussies1129's Avatar
Trader Rating: 74 (100%+)
just running in a 353 race 09 now and couldnt help but notice that during a few tanks on the box its was getting up to around 80-85celcius , compared to 65-70 on my 3sct? must be a leaner needle setting from factory?
cheers
aussies1129 is offline
Old 08-19-2009, 09:09 AM
  #178
cheers
that's the temp they should be reaching whilst breaking in. Idle it for only one tank to clear out the junk and to run everything in slightly, then for the second tank begin to drive it just blipping the throttle, loading it up, and get heavier ont he throttle every tank. by the 5th tank you should be holding down the throttle down the straight, and it should be rich-ish maybe about 110 degrees celcius.
then just go by feel.you can see when an engine is breaking in as it gets richer each tank as the piston/liner fit expands and breaks itself in, when this occurs every tank, lean it just a fraction then run it like this for the rest of the tank.
TomB is offline
Old 08-21-2009, 03:02 AM
  #179
thanks Tom , ran it last night and it feels as quick as my previous nova 3sct, must of been the cool air cause it wasnt running over 90-95c with good smoke.
cheers
Old 08-30-2009, 08:09 AM
  #180
has anyone else who has a 353 '09 found that the bearings don't last long? someone at my track had the front (small bearing) go after 1 litre, and one other person had the bearings go also.
does anyone know of a good quality replacement bearing front and rear for the new 353 '09's?
TomB is offline
