HPI Cup Racer 1M
#1231
are you running stand-up or lay-down front shocks?? If you're running stand-up, lay the shock on the inner most hole, that will make the fronts 'harder' and force more weight on the rear shocks....you can also try standing the rears all the way out (outter most hole), this 'softens' the rear shock
i gotta look at mine again, but i know i was running the hardest of the option springs in the front, and the softest rear spring - but then did a little 'experimenting' and was able to go the blue spriings in the front and grey in the rear....i'll try to go over mine and give you the setup - i think it worked really well
#1233
Well, they got some 'exsplanin' to do to you then
Check out page 31, bottom column as evidence to what I'm saying;
http://www.teamxray.com/teamxray/sho...p?file_id=2525
This is a great tuning guide for all racers- including Cup Racers
#1234
Got my second Cup Racer yesterday!
Does sombody have an racewinning setup for indoor carpet racing?
#1236
#1237
Sure, http://www41.instantestore.net/merch...rc18r-wing.cfm
Mounts up nicely on any flat surface and the perfect width
#1238
Almost forgot! Another good tire (a close 2nd to the Atomics) is the ABC Hobby slick;
http://www.abchobbyusa.com/tiresandwheels.aspx
They are good guys there and super helpful.
#1239
hey there im new to this forumand was wondering if someone can help me with my front camber problem on my cr.every time i set my front upper arms to the same length via calipers the right side comes out to -1deg. and the left is -2deg. ive racked my brain over this for weeks thinking somethings broken or cracked or maybe its a manufacturing flaw.so far theres nothing broken or flaws that i can see. has anybody else had this problem or have a cure for this would be greatly appriciated
#1240
#1241
thanx redmike76 i actually did the same thing.i was just curious to see if all kits were the same or if it was just me. does anyone no if abc's rear turnbuckles will work on the cr,would make it alot easier to adjust rear camber?
#1242
Are you guys using that wing on pretty much all the body styles, leaving them clear?
I know my 510 is kind of "skate-ey" sans-wing. Was thinking of a body change, but if that would cure it it would be cool.
#1243
A Question for those who have built the Porsche RSR
A few points that I haven't seen covered before when using the Porsche RSR body:
1. Lay Down or Stand Up Shock position? (pg 18-19)
2. Lay Down or Stand Up Servo position? (pg 24)
3. Spacer under steering posts? (pg 15)
4. Spacer under rear gear case? (pg 21)
I thought these might be covered in the instruction manual for the body, but not so.
Thanks!
Thanks!
#1244
#1245
Thanks!
Thanks!
If you look at my picture i think you can se that it works both ways on the shocks!
And the servo is lay down on mine!
