Pro-match Batteries
#1111
Eddie G aka R. Kelly......
#1112
Good question Neil! I have been wondering about the same thing. Looks interesting.....
#1113
Yes, me too. I plan on building my M18 sometime after Reedy It should be a nice distraction hehe.
#1114
New Problem
Ok, this morning I hook up my other battery pack I built last night and when I put it on the charger it tells me "No Battery".
What do you think might be the problem. I have looked them over and all the bars are connected well and in the right manner. Does this sound like a charger or battery prob? The other pack I built last night charged up just fine. HELP!!
#1115
Re: New Problem
Based on your previous message, you said that you have Quasar Pro charger. Check to make sure that all the leads are connected to the alligator clips. I used to have one of those chargers and when one of the wires came off, it said "No Battery". As soon as I soldered it back on, things were fine.
Try charging another pack to see if you get the same error.
Also, if you have access to a voltmeter, you can check the voltage of the entire pack or each cell just to make sure everything is in order. Sometimes, even if a cell looks like it is soldered on correctly, it may not be. The voltmeter can help you identify this and find which cell is the culprit.
I hope this helps.
#1116
rtypec- thanks for the reply.
When I put my other pack on the charger again it works just fine so I think that rules out the wire leading to the charger not working.
I dont have access to a voltmeter but I will check my solder joints again carefully as this seems to be the logical explination. They lookand feel solid but I'll look em over. I hope this is the problem!
#1117
Fixed It
Thanks for the advice!
I looked over the bars and put more solder on some I thought looked a little weak and voila!!!! It works!!!!
Thanks again!
Thanks again!
#1118
AE_T4: Next time give our assembly a try... you will be VERY happy with it.
#1119
what does assembly cost?
#1120
#1121
thanks for the link
#1122
any hints as to the May specials???
I am ordering either tomorrow, or maybe Saturday if you hint that I should wait!!!
I was going to order minimum of 5, maximum of 8 (can't decide) of the .164-.169 matched 6 loose and get the deans bars for free. Plus an 8 cell battery case.
Or maybe bulk specials? I have two other people wanting 4 packs a piece.
#1123
Give Erika a call.... 1-928-855-2226 she can tell you what's coming up.
#1124
*ring ring*...... Hello Erika?................ Wassupppppppppppppppp!!!
#1125
Good Afternoon Pro-Match Racing..................wasssuppppppppp!!
Eddie~ Thanks for the pic............yeah what is up with you being the ONLY one with a tan????? Those are some WHITE boys.
Mako~ I am assuming it was you I spoke to earlier on the phone. I will update the site first thing in the morning.
My wonderful marvelous boss Jeff Roe has given me the day off tomorrow to go on a field trip with my son, but I will go in and update the site and of course do paychecks
