Pro-match Batteries
#482
I totally agree
#483
Ok, but I thought increasing the cutoff would make it peak even sooner and its already only registering 3100mah.
#484
Increasing the peak detect will make the pack peak later. .03 v versus .05 volts not the other way around Say your peak voltage is 9.0 volts, it will shut off at 8.97 with .03 and 8.95 at .05. The .05 will increase the amount of charge you put into the pack plus bring the pack up to racing temps.
#485
PS Boosting the charge isn't gonna solve your problem. The only option is the drop back(or cut off) voltage setting. Boosting the amps you are charging at will only give a slight increase in voltage and decrease the life of the cells.
#486
#487
Thanks for the help guys
#488
Oh my at the confusion..... Set your charger to peak at the higher voltage.
I think he was trying to say if you have your setting at .03 and the pack peaks at 8.97......... set it to .05 and it will peak at 9.00 or higher. .05 will hold the peak longer than .03..... but keep a eye on the pack till you are sure it won't over charge your packs at that setting.
#489
AE Racer,
Still kinda confusing. My understanding is this...When a pack has reached it's peak the voltage starts to drop off. With a peak detect set at .03, when the packs voltage drops that much (.03) the charger shuts off. Therefore, with a peak detect set at .05 the charger continues to charge until the pack has dropped .05 which takes longer than if the pack only dropped to .03 thus putting more charge into the pack which in turn will increase the heat in the pack. Ideally you want your packs to peak at 140 degrees but many factors will determine the cut off / peak detect voltage that you set your charger to. Where I race, the indoor facility that we use in the winter is exteamly cold, so I need to set my cut off a little higher than if I raced where the ambient temperature was 80 or better. Hope that helps.
#490
That is correct jjmudd. The .5 cutoff holds the charge longer because it is waiting to see the voltage fall back more than with the .03 setting.
AE: Don't sweat it dude,we don't mind helping you out at all. That's what we have this for.
#491
Is it ok to run a pack right after you take it off the charger at peak temp? Or should I let it cool down first? It seems like it would get dangerously hot while running if I ran it right off the charger.
#493
This one I do know the answer to......ideally run the pack right after it peaks (made me feel good to know the answer )
#494
Oh yeah thanks guys....I have learned a lot from this too
#495
Originally posted by jjmudd
It is always best to run the pack as soon as it peaks. Ideal situation is: battery peaks, gets put in car, car on track and race. If the pack peaks before you need to race, keep it in it's box or other storage area so that it can stay warm.
Thanks for the help everyone.
