Bought a used RC8 roller what direction do I go now?
I have a mach 427 in my 8ight and its a great motor, tons of speed and power and easy to tune.
Go Tech fixed their carb issues. The newer carbs have a short LSN like a Novarossi carb and they tune quite traditionally meaning you tune the HSN then the LSN. IF you do go with a Go tech that has a long LSN then you tune with the LSN the adjust your HSN. Once you learn how to tune the Go Tech engines, the power and performance is equal to the high dollar mills IMO.
How would this SH engine from jbrow1 be? It sounds like a good deal? Any thoughts? My hobby shop is reccomending a RB engine A 5 I think. I'll get some pics up tomorrow and more info. I didn't get a clutch flywheel or collet. I do believe this car started life as an RTR cause it has no carbon fiber parts on it. Thanks for all the info.
#20
To tell if your car is a rtr or FT easily just look at the topside of the chassis uner the fuel tank. It's milled out to say AE or rc8 under the tank (I forget which) and the rtr chassis I believe has no millings.
Alot of guys put the plastic pieces on the ft car anyways. I run the rc8 and have put all the plastics on my car instead of the CF. The radio tray is more user friendly to install servos, the center diff top plate protects the brakes from spills better, and the chassis braces make the car feel better in your hands but feel the same on the track.
Sportworks clutch bells are a direct fit for the rc8 also. I believe they are cheaper than the ae ones. And for clutch shoes check out impulse-rc.com best shoes on the market and only 12 bux a set!!
#21
I sent you an e-mail on the engine. I'm 99% sure I have an RTR RC8. Thanks for your help.
Well I'm not one of the guys that is going to tell you my engine will run with the vspecs or the novas. I run a nova outdoors in the summer. The SH engines are good reliable little engines that are great to learn tuning on, and they can be competitive on shorter or tighter tracks. They say your first nitro engine you should only expect half the normal life expectancy from it while you figure out the basics of tuning. RB's are great engines and reliable as well. Lots of power too as well. The engine I am sending has a new collet in the box. Most all engines come with a collet new.
#22
go the go fast direction!
#23
Perfect
Reciever packs. I like the intellect IB 1600 they hold a charge longer than other 1600 packs.....A main Has their own brand PRo Tech that uses these cells for like 18 bucks.
Servos. I like the Ace 1313 for steering and a high speed futaba for throttle, but two 1313's would be nice. At 75 bucks they are really nice and last a long time. A cheaper 40 servo would work ok though with at least 80 oz of torque....
OFNA starter boxes with twin motors. I like the silver top one. with the power panel that includes a wired glow igniter, can't loose it at the track.
An ofna or dynamite 053 or 086 pipe and maniflod combo is around 55 bucks that's a good price...
Radio. MX-3 2.4 ghz is nice at 150 dollars....It's an Airtronics. Fits good in the hand and has plenty of adjustments....
Hope this helps....oh yeah the mc coy mc-8 glowplug is the best for Novarosi engines. Standard plug....
#24
get a jammin jpx .21(picco) motor and 086 pipe
#26
Servos: I would strongly recommend Hitec servos or the JR HVs (those are pricey but they are bricks), as for the 1313 - yes they are good but you really need to know how to adjust your EPAs for them to last.
I didnt see anything about price? Are you on a budget?
#27
#29
If you are on a budget then go for the alpha engine they have been ripping it up at my local tracks my next choice would be a b5. Both are about $200 and descent. As for servos go hitec 79xx. Stay away from the jr hv servos I spent the $$$ and put them in both of my cars. One failed by the 3rd race. Hitec servos have been running strong. They even survived the nitro pit nitro challenge in feb and them silverstate in march. I use a 7940/7950 combo but any 79xx series will do.
#30
