17.5 BL motor gear ratios
Hi guys I'll be running a 17.5 Speed Passion motot in Stock but the suggested 4.6 - 6 gear ratio seems a bit slow?
Has anyone else got a suggested ratio I can start trying out??? I was thinking of about 3.5~3.7
Any suggestions???
Any suggestions???
Thanks. I'm runnig it in a TRF 415 MSX MRE and I'll be getting a 80T 64p Spur and using the 51T Tamiya 0.4 module pinion. Together I should make a 3.5 gear ratio and I've got a 83, 84 and 85T spur aswell so I should be able to gear it all the way from 3.53 - 3.75 and above...
Stupid question, but has anyone raced a BL 17.5 against a 27T brushed motor??? How did it do?
Sweet thanks... Exactly what I wanted to hear
This might be a real stupid question!
Has anyone ever had this issue... Way back when I got my HPI Pro 4 I ran it at a 32mm roll out or something with a 96 spur and 36 pinion. That nearly fried my 27T motor... But when I changed the gears to something else - 82T spur and 31T pinion it ran like a dream?!?!?!
It might just be me??? Help
Hiya
I am running a 415msx with the stick pack chassis bulkheads and the upper deck so my lipo's will fit. Does any one know the part number for the stick pack chassis upper deck.
I cracked a standard one previously so I would like a spare for my pitbox just in case.
cheers
Dave
cheers
Dave
