OS Speed 12XZ engine ~~FULL PHOTO~~
#46
What is your safe temparature for this motor'
Thanks'
Thanks'
#47
#48
have running mine with 1/2L 5% and 1L O'D 20%, then turn it to race run, compare to Spec II the XZ had more bottom power and great top speed , i ran it about 95 to 100F and with a RP6 plug, OS t-1050 pipe, will try RP7 plug next time.
#49
Trader Rating: 9 (91%+)
I ran it on State Title with stock plug (RP6) and T-1050. Heaps of bottom end power compare with Speed-I and Speed-II. Especially with T-1050, it makes the XZ sing! But so bloody thirsty!!!
#50
yep, the temp i ran with have had arround 5m15s run time so next time i will test if RP7 can help a little more.
#51
what restrictor do you use? I seem to be able to get more than 6 min all the time using RP6 and 1050
#52
#53
20% or 30%?
Does this engine come shimmed for 20 or 30%? If I run 20% does that help with run time?
#54
#55
#56
never mind post above
saw the pics, appear as .3 for shims (1 .1 & 1 .2)
#57
besides sage and os1050 pipe, what other pipe is suitable for a technical short track?
thanks in advance
thanks in advance
#58
#59
pipes
For longer tracks I use
the Mugen Pipe 2501
the Mugen Pipe 2501
