Serpent 710
I dont know much about the MR12, but I am sure that the MR12 is similar to the NS12S3, and one thing I can tell you is that if it is run-in right, you will not be dissapointed.
do you guys suggest any other engien.i heard turnos are hrd to maintain like as in when the sun goes away u nee to change go plug immediately is that true? is there a big power difference between turbo and other engines?
Suspended
RB CONCEPT V12 IN 710
ANY OF YOU GUYS THINK THE V12 WILL BE GOOD IN MY 710?
The main difference is that the turbo plug motor is more efficient and can make more power. One can go slightly leaner than with the normal plugs. Also the Turbo plug has not got a washer and seals differently.
Other than this, I dont think you will have a problem with the tuning like you are suggesting.
Re: RB CONCEPT V12 IN 710
I dont know this motor, but if it is a .12, It should do well, I have a standard NS12S3 and it REALLY screams... I think the V12 will too. Give it a try, I am sure you will not be dissapointed.
Suspended
Re: Re: RB CONCEPT V12 IN 710
Originally posted by BaxterC
Hey Freaky...
Hey Freaky...
Re: Re: Re: RB CONCEPT V12 IN 710
THANKS A LOT...
THANKS A LOT...
Rb V12
Hi,
I have a V12 Rb rody tuned in my 710.
It is really great.
It's by far the fastest engine I have ever had!
Didn't have to make any modifications, because it's having the same base as the Novarossi's and Novamega's.
If you're going to use it I would also use the Rb pipe.
I have tried the Rb pipe, and the Novamega pipe, and the Rb is working better for me.
Quality is great of both pipes!
By.
It is really great.
By.
Hi there, I think what you have heard is a little EXTREME to say the least. I would have gone with the Turbo if I was able to but the Race rules here are a little tight when it comes to the Turbo plugs.
Suspended
COL
COOL...HOW IS THE V12-430?
thanx now whats a relly good turbo engine under 300? i would like a purple top to match car lol thanx again i was sacred to get a turbo there for a second i ony have experience tuning a os max .12 cv-rx for my rs4 2 rtr
Dont be scared... I am sure it will be similar to the OS max. only thing is that a turbo motor will be a little more advanced. if you have the OS down to an art, then a turbo will be the next step... I would suggest any of the Novarossi or novarossi based motors. Try www.rc-mushroom.com or www.towerhobbies.com. you will find some decent prices. Remember that any motor with a turbo plug will have decent power and should scream as there is no sence in putting a turbo plug in a mediocre motor as it will be a waste of time for the manufacturers.
is this a turbo? and is the price good? ill snatch it up right now
also is the rd logics turbo II one piece
pipe good for this or what better?any links to it?
http://rc-mushroom.com/product_info....oducts_id=1095
Originally posted by InitialD
Perhaps... But remember gear ratio as well. They may seem to be better on smaller tracks because of the high gear ratio.
thanx now whats a really good turbo engine under 300? i
Since conical plugs are legal I don't think you will find many top engines with a standard plug.
The NSR 12S3 is a 3-port so should be legal wherever you race. I have this engine in my 710 and it's simply awesome... Currently running it with the older RD Logics, but my TurboII is on it's way! If it's better than the old one (which it should be) you can't go wrong with it.
