Serpent 710
Originally posted by InitialD
The old ones were yellow. New ones are white. But I think the rear belt remains yellow because those are still from the rear Impulse belt.
D, what's up - you've not commented on all the new products from Serpent yet Are setup wheels woth while having?
Setup wheels? I have not seen those yet ! I've only seen the yellow shoes as like you have.
But in all truth, the generic setup wheels that I've seen can be prooved useful as I find you can set up the car quicker than you could with the Hudy prisms. Especially during race day. With a camber gauge, you could take pretty accurate camber and toe readings. I think the only thing you cannot do is take front toe.
As the setup wheels come in a specific diameter (62 mm if I'm not mistaken), you could take ride height without making any adjustments assuming you run 62 mm most of the time. You could also check tweak with the lift method as the setup wheels are accurate.
Originally posted by FW05R
what color is the writting on your 710 belts?
Sorry. How I wish Serpent would just drop them my mail !
The set up wheels are 64 mm in diameter. How can you measure your toe accurate with these wheels. Using a ruler or your cambergauge?
http://www.mytsn.com/products/desc.asp?prid=3804
Originally posted by Herbie
If you'd go this weekend to MACH you will be dissappointed because they've got new tarmac so no driving only for those who helped. http://www.mach-heemstede.nl/
But on Sunday we have our nitro club race, so it's still no good to come.
Also its more fun to come when the weather is better, its been raining all week (thats going to be fun to have a race on new tarmac)
Originally posted by Schrijver99
That is only till Saterday 13:00 after that the track is open for all.
Schrijver - how is the "rijv" part of you name pronounced - I take it "Sch" is the same as in German?
For the rear toe, just make the rear end of the car stand on a flat surface with the front end of the car pointing upwards. The car should be resting flat on the rear shock towers. Then use the camber gauge to measure the rear toe in.
Originally posted by Pyramid
Based on your nickname, I would like to asked your opinion regarding FW05R out of the box durability compared to S710. It really makes me wonder when someone said it is more durable than S710. For instance, does the stock gears will hold long enough life when powered by Max S5 engine?
Damn. Did not see the new product releases !
But as I can't race anyway, then I'm pretty happy the weather is so bad
lol D your right on the color the writting is white but my rear belt is also white what does that mean?
And I thought I was cruel...
Sorry Master D must be the force
So I did measure the toe just as you mentioned thanks
