Serpent 710
Originally posted by buboy28
i think "D" could answer your question but if you dont like the plastic shock bodies there is as optional aluminum threaded body shock. i did change mine from plastic to aluminum
Originally posted by Pyramid
May I know why?
May I know why?
Originally posted by crashed_1
For one, they don't crack upon impact...i've seen one too many plastic shock body breaking at our local track...
The only thing I don't like about the composite shock bodies is the upper thread where the shock cap is attached strips easy if you're not careful. Very fine thread. Aluminum shock bodies will last and last.
Also, there is another thing about Team Serpent drivers preferring the composite bodies to the aluminum ones. Apparently the composite ones provide more consistant performance...
Nova Max Massimo Fantini
Originally posted by InitialD
p/s: Where have you been hiding Mark?
I was talking to Sow about my settings last night (in the 3hobby chat room - you should try it ) and it seems I've probably been setting my LSN and HSN too lean, as I was trying to compensate for a badly setup engine. I was basically going the wrong way with both the LSN and HSN.
I had thought I had had a rich bottom end, where in fact it was probably the HSN which was rich. I had adjusted the LSN to cure this, which it did, but probably only because it affected the HSN. Then I had to reduce the idle screw to stop the engine from idling too fast, etc, etc.
You said above about adjusting the LSN until the revs start to rise. So basically the idle remains constant, you turn in the screw a bit (1/12th)......listen to the idle - if it is still runing at the same revs turn the screw in a bit more. Repeat this until I do another 1/12th turn clockwise and then the revs rise a little - I stop and richen 1/12th?
Got my spare JP
crashed_1
Glad to see your avatar is nice and gentle again
Got my spare JP
Got my spare JP
Maybe you have not done what we wrote...
Re: crashed_1
Brutus the RAT...
Did you crack yours?
He dont like the way alu. body react to the track temp. Hotter ambient will lower the visco.
Personally. go with aluminium body! will save your shock budget
I'm jealous !
I'm jealous !
Re: Re: crashed_1
Brutus the RAT...
Brutus the RAT...
I'm jealous !
I'm jealous !
