Serpent 710
Old 05-17-2004, 07:06 AM
  #10651
stormperson's Avatar
Hi,
I currently run a FT NTC3 although after being disopointed as how litte it was better than the first car, I am planning on buying a 710, however, I had a few Q's
1)Who stocks parts online in the US?
2)Can you get CVD's?
3)What wears/breaks? (IE, what should I stock up on)
Thanks!
stormperson is offline
Old 05-17-2004, 07:13 AM
  #10652
markp27's Avatar
Originally posted by crashed_1
I feel your pain man...i just had my Max replaced with a new piston/sleeve and both front and rear bearings. My fault coz i didn't do a check on my engine after the last race and went on to start it...not knowing it had a broken filament inside. It managed to start after replacing a new plug but it sounded horrible as there was a grinding sound coming from it, but silly me went on to play After a tank or two, the idle kept fluctuating and then disaster stroke...it didn't wanna start no more. The piston head had little bits of metal stuck to it and the buttonhead felt like it was sandblasted.
Thanks bro! This motor is a gonna - just check the prices for the spares I need - cost more than the engine itself
Something went big style in the gearbox/engine deparment after the hit yesterday - the clutch shoes shows signs of wear just in one spot I think I'm going to replace the clutch bell, gears and bearings of the centax whilst I'm about it - oh man is this going to be expensive
markp27 is offline
Old 05-17-2004, 07:34 AM
  #10653
BaxterC's Avatar
Man, my head is sagged in pain, I feel it with you. It is like the death of a great pet. man. why dont you contact the engine maker and see what they say?
BaxterC is offline
Old 05-17-2004, 08:06 AM
  #10654
KevinS's Avatar
Just checked - the bearing on the bottom of the conrod (where is joins the crankshaft) has disintigrated the conrod then went on to take chunks out of the crank case and the resulting shards of metal damaged the liner and the piston......looks like a right off to me
Sound like that Mugen hit the clutch deadon and actually pushed the crankshaft into the engine, causing the piston not to line up with the sleeve. That's the only way to explain the broken clutch bearings and conrod bushing and the damage to piston and sleeve.
A nightmare for most of us, but you are living it.
KevinS is offline
Old 05-17-2004, 08:34 AM
  #10655
markp27's Avatar
Must have been something like that
Well under the circumstances, there's only one thing to do......grab a beer
markp27 is offline
Old 05-17-2004, 09:28 AM
  #10656
crashed_1's Avatar
Nothing like a good lager fix. Btw, what engine are you running?
crashed_1 is offline
Old 05-17-2004, 09:43 AM
  #10657
markp27's Avatar
I was running the #2106 SX-12 SS 3 Port nice engine!
markp27 is offline
Old 05-17-2004, 09:48 AM
  #10658
Wap
Unfortunatly mark i believe that motor is sold out; i can't find it anywhere; if you find one let me know.
Wap is offline
Old 05-17-2004, 10:10 AM
  #10659
rcpanama's Avatar
Smile Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Need some setups
Originally posted by InitialD
Hey Marcos, did you try it out?
Hi I D I have been a Serpent Driver for two years and I have since February a 710, I have been reading this Forum for the past two month every day and Glen article in MYTSN Forum.
When I read your Set Up it look good for the Track we have set up in Panama (Parking Lot) so I was going to try this one with the front Ball Diff, with some changes instead of Yellow Spring I used Red, our track is not bumpy.
Yesterday I when to the track and try this set up and it was amassing, the car was excellent, I improve the timing by 1.2 second because in the curve I could go faster (very technical two chicane), in the straight it was very fast.
I was not able to have on time the 57 gear so I had to use the 56 so I could not test it with the that combination. I will be receiving this today from Serpent USA, so this week end I will test it with the same combination you have to see if I can improve even more.
In our club we are only three Serpent and 11 Mugen, I can say that after this week end the Mugen gays where really concern.
I have install in the 710:
Complete set of CERAMIC BOCA BEARINGS
The NOVA MAX 5P
Tuned pipe-set Inline M12 TP05 Outlaw
Ellegy 40 with Disk front 6 rear
Futaba S9550 for Th. & St.
Receiver Futaba R203 HRF
Radio 3PK
Drive-shafts front & rear Part: 808220
Wheel axle front & rear Part: 801214
Brake disk stainless steel ventilated Part: 801345
Shock-body alum. Front & rear
Shock membrane soft & Foam inserts (4) Part: 909446
Shock Seal-Shim Alu (4)part: 909408
Sorry for the english
Jose
rcpanama is offline
Old 05-17-2004, 10:52 AM
  #10660
serpentracer1's Avatar
Stormperson,
Winners Circle has a complete selection of parts for the 710 He's located in Ga You can call also he has a toll free number ask for Lee.
1-866-nitrorc or
http://gasrccar.com
Hope that helps
serpentracer1 is offline
Old 05-17-2004, 11:48 AM
  #10661
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally posted by serpentracer1
Stormperson,
1-866-nitrorc or
http://gasrccar.com
Hope that helps
cool website , thanks
Marcos.J is offline
Old 05-17-2004, 01:47 PM
  #10662
rwisejr's Avatar
Talking Re: Re: Re: Re: Bag 14
Originally posted by buboy28
JUST GOT MY MISSING PARTS FROM OUR LHS BAG #14 CONTAINS ALL THE GRAPHITE PARTS AND YOU ARE RIGHT PSI Racing SERPENT IS GOOD IN REPLACING MISSING PARTS NOW I CAN REALLY FINISH BUILDING MY 710 THANKS GUYS.............
Well hop to it dude.We don't wanna hear from ya till its done.
rwisejr is offline
Old 05-17-2004, 01:55 PM
  #10663
John Fontaine's Avatar
Originally posted by stormperson
Hi,
Thanks!
Storm - I would check out www.ashfordhobbies.com
He is a huge serpent hobby shop and hudy/xray as well. He stocks all the kits/parts/upgrades and in CT you probably can have parts in a day. Robert is a great guy and a racer himself and has lots of business hours to get ahold of him, email or phone.
John
John Fontaine is offline
Old 05-17-2004, 05:02 PM
  #10664
I finally got my engine / clutch working the way I like it .... I just wanted to share lol
Profoxcg is offline
Old 05-17-2004, 05:05 PM
  #10665
i wanted to know, what can I use to clean my bearings? what is also good to relube them ? i cant seem to find serpent oil
Profoxcg is offline
