Serpent 710
#8446
Originally posted by Profoxcg
Am i the only one with the problem of the front wheels rubbin the nuckles??
even at the smallest bend?
has anyone tryed to use 835 front nuckles, or other nuckles for that matter succesfully?
Here's the web site info http://www.twistertires.com
#8447
Re: Re: front bumper plates ?
Originally posted by cox049
I got my parts order in today and the Bumper Plates are the new reinforced type
#8448
Re: Re: Re: Re: Re: Re: Re: Re: scratched piston
Originally posted by AMGRacer
I had a Rody 5 port which blew a rod. I had it tuned perfectly cutting some great laps around 10 minutes into a final.
#8449
Re: Re: Re: Re: Re: Re: Re: Re: Re: scratched piston
Originally posted by InitialD
Sorry for the loss. What pipe were you using? Shark? Shit happens and when you're in the final, somethings everything else blocks out...
#8450
Re: Re: Re: front bumper plates ?
You guys probably cleared all the 710 bumper inventory that Serpent had to make new ones. Kudos to Serpent.
#8452
Re: gear ratio Q
Originally posted by jfc_tech
Just curious about the 1st gear final ratio. I wonder why serpent want the default 1st gear final ratio at 6.618? is this the near perfect ratio for harder accelaration? or should i go higher to 7.031(16/60)? am using Max. Please advice. thanks.
Serpent usually gives pinion and spur that is in the middle. (17T instead of 16T or 18T, 22T instead of 21T and 23T, 56T instead of 55T and 57T and 60T instead of 59T and 61T) to cater for most tracks.
#8454
Originally posted by markp27
Simply drop them a line via the email address: [email protected] - works for me
#8456
Re: Re: HARD 2503 1-pc inline pipeset - adjustable
Originally posted by GlennCauley
Here is a pic of the installed pipe:
#8457
Re: Engine
Originally posted by Voodo_Magic
Ok putting back together an will try tonite everything should be ok thanks agian for all your input harsh or not it is an expensive lesson learned and a good one because now i know NOT what to do
#8458
Yeah I was having a bad day I had a Rody 5 port which blew a rod. I had it tuned perfectly cutting some great laps around 10 minutes into a final. Got hit in the pipe side in a corner and unknown to me my pressure return line got severed. I continued to drive it and felt the bottom end go soft, then really soft (crankshaft overheat). About 1 minute later goodbye Rody. Engine was totalled only thing salvagable was the carb. I did not listen to what the engine was trying to tell me
#8459
Originally posted by BaxterC
Thank you, I have mailed them but I have not had all the responses. Anyway, i will try again. Thanks
Cheers, Mark.
#8460
Oh man... i feel for you... that is a bad one... can you show us pics? I think I must open a thread Called... RC Banged-up... could be like a sick RC porn thread, showing the damagesd internals and all...
