Serpent 710
#7801
Re: engine
Originally posted by Voodo_Magic
no thats it it lost all its punch at first i thought i had siezed the clutch or the diff was loose but all of that was ok?
On a long race I always run the LSN a little richer than usual because it will lean out after around 15 minutes.
#7802
InitialD,
Do you know all the ranks and number of posts to get that rank?
#7803
Hi InitialD could you please Can explain me more deeply your break in method, like what temps should I keep and details like that?
Thank You
Thank You
#7804
Re: Re: engine
#7805
Originally posted by PSI Racing
InitialD,
InitialD,
#7806
Re: Re: engine
Originally posted by InitialD
Perhaps you're right then that the engine overheated... Did you open up the engine to check the internals and check if the compression is still there?
#7807
Thank You
Thank You
#7809
Re: Re: Re: engine
ok i have jus tried to turn the fly wheel and it spins around 60 deg and the it is hard ot turn the next 30 deg and so on. I have taken off the head and the top of the piston is black, the flywheel seem hard to turn when the piston is comming to the top of the engine ( like the top is smaller than the bottom and it rubs) sorry for all the questions iam new to this engine tuning!
#7810
Re: Re: Re: Re: engine
Sounds fine. I think the loss of power was a little warning by your engine that you were a shade bit lean. A properly tuned motor will run with the same power no mater how long you run it. If this happens again pull into the pits and get your pitman to richen the lower needle or middle needle a 1/4 turn (middle if it is too hard to get the lower one with body on).
#7811
#7812
Re: Re: Re: Re: Re: engine
Phew i thought i had done some damage then! just to clarify richen the bottom end 1/4 of a turn is turning the screw counterclockwise?
If your motor still has pinch at the top when hot without the plug it actually is not even run in fully yet.
To do a proper compression test you can do this:
1. Remove the motor from the chassis and remove pipe.
2. Spray a little fuel into the exhaust port and turn the motor over once or twice.
3. Roll the flywheel over while holding the exhaust port up to your ear. You should hear hissing which then stops as the piston nears the top of its stroke.
4. Hold it still before it fully turns over. You should not hear any hissing for at least 10 seconds. Less than 10 seconds is still OK but the motor is no longer in its prime.
#7813
Re: Mazda6
Originally posted by PUNISHER
I got to run my Mazda6 for the first time last weekend and was very impressed how well balance the car felt. Its between a 2.1 Stratus and an Alfa Losi. Has good front-end downforce like the Alfa but without the agressive feeling (smother). Also I heard that Protoform just lost the rights to make the Stratus bodies so this Mazda6 is a very good replacement!!
Here is my Mazda6............
#7814
Re: Re: A second look....
Ah, that's better ! Nicer without the background props !
#7815
On the subject of engine tuning.....I can get my engine tuned pretty ok these days, but one problem I often have is re-starting the engine when it is hot.
Does this indicate that the lower needle setting is too lean or too rich?
Cheers, Mark.
Cheers, Mark.
