Serpent 710
#7756
A second look....
Thought I'd post a couple more pictures of my new colours, as the one last night was a bit rushed
#7757
oops hit the wrong button
#7758
and the other one.
#7760
Anyone know how heavy a stock FW05R is? My friend had one at the track and I notice it was much heavier compared to the 710.
#7761
Originally posted by InitialD
I think last weekend was a bad lunar thing for the snake !
On the first tank, just about the second corner, powering out and I took it wide coming out and slammed the metal fence barrier ! Checked the car. The upper bumper brace buckled a little in the middle where the impact occured. The lower bumper was intact. The front edge of the chassis had a groove in the middle (coincided with the hole on the front of the Loletta shell) as a result of hitting the sharp edge of the metal fence pole. Only the left shock popped out of the ball located on the lower arm. Other parts did not break. Then I noticed also that the tank also cracked. But the worst thing was the chassis bent slightly in the front and worst part also in the middle ! I guess that was one of the reasons why the tank cracked.
So now after fixing everything, my baby has a new chassis... But on Sunday, did not get to test it out because of rain !
#7762
Mazda6
I got to run my Mazda6 for the first time last weekend and was very impressed how well balance the car felt. Its between a 2.1 Stratus and an Alfa Losi. Has good front-end downforce like the Alfa but without the agressive feeling (smother). Also I heard that Protoform just lost the rights to make the Stratus bodies so this Mazda6 is a very good replacement!!
Here is my Mazda6............
#7763
Re: Mazda6
Congrats!!
#7764
Re: Mazda6
SUPER paintjob (i wish i was only half as good)
#7766
Re: Re: Mazda6
Originally posted by cox049
Awesome paint job Punisher!! What did you do around the windshield hole??
Congrats!!
Congrats!!
#7768
Re: engine tunning queston - should i post is here?
[QUOTE]Originally posted by Profoxcg
[B]eveyone's car at the track today where pretty clean, no oil on the pipes or body where the pipe comes out. however mine has a lot of oil and dirt and oil residue. I was wondring, this could be because the car is too rich correct?
You could be too rich, but there should be visable smoke coming from the engine, and this WILL leave oil residue on the pipe and body. Check your temp, you should be running your engine as cool as you can and still develope maximum power. If your friends run so lean there is no oil on the pipe and body, you should go in the business of selling engines!
#7769
Re: Re: Re: Re: Re: servos
In what situation will you notice 180 oz of torque on a 1:10 on-road car??
#7770
my engine is running at 230 F.
but ut gets very dity, i mean my pipe and even the side of the car is all nasty with dirt and oil. I can understand some, but this thing is drity as hell.
how i do know my low end if too rich or lean?
