Serpent 710
#7276
Originally posted by cyba888
What do you guys use to clean your engine? I was told to use cleaning alchohol.
#7278
Originally posted by InitialD
Internally or the engine crankcase externals? Alchohol should be OK for internal and external. I use those commercially available nitro cleaners like the one below;
#7279
Which fuel would you recommend using, Tornado or Byron? Im currently using Tornado 25%. They should both be about the same correct? These are the only 2 type of fuels my lhs carries.
I have ran both fuels before. Ran the Byron sometime back and I remembered it to be excellent when it came out compared to the rest of the available fuels. But later on I noticed that I had tuning problems. I found that the fuel was difficult to tune and made the engine very blubbery ! I also noticed that I used to get the bottles with sealed tabs but not anymore. So when Tornado came along, I switched and never looked back ! Excellent fuel ! Consistant performance all around, easy to tune and most of all, power !
#7280
I dont think they have that stuff here, even if they do it wouldnt be worth the price. I think alchohol will just do fine for external cleaning only.
#7281
Ok. If for external use, I use the commercially available brake cleaners that you get from DIY / Auto shops. That's when I have to spray a lot to get all the gunk out.
#7283
How do you get all that gunk out, dont you need a air compressor to blast it away or do you wipe it down with a q-tip?
#7284
With the brake cleaners that comes in compressed cans, it's not a problem. Just blast them. If you use alchohol, you'd probably need an air compressor. Else, like what you say, use q-tip.
#7285
I plan on using a toothbrush to clean the engine with cleaning alchohol. But for rinsing would it be ok to use a little running water, if Iwere to avoid the carb, fuel hole and heatsink?
#7287
Originally posted by spawn
dont use brake cleaner on your nitro car! bad for plastics and skin!. melts soft plastics.
I found out it was corrosive when I used a little bit of it to clean the bodyshell ! Spray on a little on the tissue and wipe the shell. When used carefully, it's an excellent skid mark cleaner on the bodyshell !
#7288
Thanks for reminding ! I only spray them directly at the engine crankcase.
#7289
As a skid mark remover, break cleaner is second to none!
#7290
Re: Re: Re: Re: Re: Re: Question for GlennCauley?
Originally posted by GlennCauley
What I really like about the 1-piece pipe sets is that they are very tough and can take more abuse (i.e, side collisions) than 2-piece pipes held together by a coupler. What I don't like about the 1-piece pipes is that you are stuck with the pipe length they set.
How I wish someone would design a 1-piece pipe where you can adjust the pipe length...
With 2-piece pipes you can adjust overall pipe length to tune your engine better. But the tradeoff is that the pipe length can change if you hit the pipe, or the pipe can come apart.
I use 1-piece EFRA/ROAR pipesets on both my S710 and S835 cars.
On my S710 I am trying the #2170 pipeset (TP06) this season (I used a Dynamite 1-piece pipe on my Impulse Pro 2 years ago).
On my S835 I use the #2690 pipeset.
We run on a smaller, more technical track (parking lot).
Cheers!
Glenn Cauley
Ottawa, Canada
Cheers!
Glenn Cauley
Ottawa, Canada
