Serpent 710
#7261
Re: Re: Question for GlennCauley?
Originally posted by GlennCauley
I have no personal experience with the TP04 pipe unfortunately.
I usually use a 1-piece "karting" pipe like the TP06 tuned pipe set (#2170).
While I hate to pass the buck, I would recommend contact someone at Serpent (Julius Kolff maybe) to find out the characteristics of this pipe.
#7263
Super Moderator
Originally posted by InitialD
Insecurity ! I think he was really pissed when he asked what bbntc3 from the NTC3 forum thought about the 710 and he replied to say that the R40 was no match and that the 710 was a different story as it is almost enough to make a man switch cars !
#7264
Originally posted by SupermaxxRich
I'd have to disagree with you guys on that Nitro doesn't make more power. I build drag race engines for a living and I have customers that run methanol and Nitro methane. Put it this way, guys running methanol only, with better superchargers, more boost and better cylinder heads make about 3000-3500 Horespower. Guys running Nitro about 90%, with less boost are making about 8000 HORESPOWER!!!! There is alot of power to be had with Nitro. The extra power that comes from Nitro is because it is actually quite explosive. Nitro actual explodes in the combustion chamber. On the engines that are running Nitro in Drag Racing, it is so explosive and there is soo much cylinder pressure that after every pass all the bearings in the engine have been completely pounded flat! Now thats power! Just my two cents.
#7266
Re: Re: Re: Re: Re: Re: Question for GlennCauley?
What I really like about the 1-piece pipe sets is that they are very tough and can take more abuse (i.e, side collisions) than 2-piece pipes held together by a coupler. What I don't like about the 1-piece pipes is that you are stuck with the pipe length they set.
On my S710 I am trying the #2170 pipeset (TP06) this season (I used a Dynamite 1-piece pipe on my Impulse Pro 2 years ago).
On my S835 I use the #2690 pipeset.
#7267
Re: Understeer
Originally posted by JPRacing
Hi guys. Wondered if you could help me here.
The tracks in my country are on the sliperry side and I am having a heck of a hard time trying to get rid of on-power understeer from my 710. I use ball diffs front and back. I have tried lower shore foams in front to no avail.
#7268
Originally posted by Schrijver99
Whoops have had the new conical in my hand today but forgot to look at the part nr Will have mine on Friday I'll post the size and pic!
#7269
Re: Re: Re: diffuser
Originally posted by JABRONI
In any event, it appears that if the rumors were to be true he could be a great addition to the Serpent Team for the Future !!
#7270
Re: My clutch slips
Originally posted by pelos
After the first 40 min run I serviced my 710. I put all together (radio tray, motor, clutch and gear) but now the clutch slips It was working perfectly!
I checked 5 times the clutch gap and the end play as in the manual. I loose the clutch spring more than one turn but the problem is still there.
I am not able to understand if I made a mistake or the clutch shoe is burn out...
Anyway, did you mod the Centax flyweights? The correct way to check the clutch gap is to take off all the bearings at the back of the clutch bell and mount the clutch bell with the thrust bearing. Then measure as per the manual.
If your clutch still slips, keep adding shims (0.1 mm at a time) to the front near the thrust bearing to make the clutch gap closer and test it out.
#7272
What do you guys use to clean your engine? I was told to use cleaning alchohol.
#7273
Re: Re: diffuser INITIALD CAN YOU ANSWER THIS QUESTION?
Sorry Marcos, that subject is beyond me man...
#7274
Super Moderator
Re: Re: Re: diffuser INITIALD CAN YOU ANSWER THIS QUESTION?
#7275
Which fuel would you recommend using, Tornado or Byron? Im currently using Tornado 25%. They should both be about the same correct? These are the only 2 type of fuels my lhs carries.
