Serpent 710
#6661
Originally posted by BaxterC
I will be up at 5 on the weekends when my kit arrives to build it, and to get to the track to run it... It will be winter here in a few weeks... VERY COLD... not like england though... only -1 C maybe -2C not colder...
Can you see sun to play in that cold weather? What time does the sun come up?
#6662
710 FAQ
The latest revision of markp27's 710FAQ has now been uploaded to my website for easy reference.
http://www.markanddebbie.net
#6663
Originally posted by InitialD
Brown shoe? Would that make for more clutch slippage? The brown shoe is harder than the XP stock shoe.
#6664
#6665
Originally posted by MrChan
I 'm currently running 200mm with 90 degree front sway bar.
I don't think I should raise up front roll center coz It was not enough steering and I believe I should raise up rear roll center first . I feel I got a lot of rear traction and make my car got traction roll !
I will try out a few things this week end ... I hope my car will not be traction roll until broke thing again !!
Last week, I broke front absorber and rear wishbone because of 2 time of traction roll. My car flew like SpiderMAN to the wall
If you roll in the middle of the corner you can use a higher front roll center (lower the pivot points of the front upper arms).
Anyway I saw you used 37 shore tires. Go up at least one step as the tire will then flex less and this helps reduce traction roll.
What body is on the car?
#6666
Originally posted by Julius
It depends on when the traction roll happens. If it is entering the corner you may not have enough rear grip. A little softer rear bar or a lower rear roll center will help.
I will try 42 and 45 this weekend.
#6667
Hey Julius, did KLM put you on an aviation course reacently - I was just wondering because of your new signature
#6668
#6669
Nope, the brown shoe has less slip than the black shoe.
"This black centax clutch shoe is made from a new material that gives you more ‘punch’ on acceleration. Although, due to the nature of the material used on the XP (xtra performance) clutch shoe, you sacrifice longevity, the extra power gained is worth it."
I would interpret that the material used on the XP shoes are softer and hence have more grabbing effect on the clutchbell... But of course, I may be wrong again !
#6670
Originally posted by Sow&Steady
Well, that would almost apply to me too when my car takes off into the air after hitting the kerb!
Hey, I still owe you a PM and register on that website.
#6671
I would think you will not be sleeping when your kit comes !
In winter the sun comes up at around 6:30-7am and goes down at around 4:30-6pm... so wwe have relatively long days in winter, but it is cold for us... summer the sun is up at around 5am and is up till around 7-7:30pm... longer days but it is hot... ~30C to ~35C
#6672
By the way did you know helicopters can't fly?
They are just so ugly the earth repels them!
#6673
I was using Alfa 156 and I got traction roll in middle of the corner when I was trying to carry more speed.
#6674
In that case running a higher roll center in front and maybe even in the rear will help.
#6675
I guess KLM thought I'd better not learn the hard way
