Serpent 710
#541
Originally posted by Rene C.
Testing that long time and already knowing to have a better car, but still driving on races with the existing car , was the hardest part of it.
#542
Originally posted by InitialD
Taken from the 710 FAQ;
is there a solid front axle included in the kit ?
Ronald Baar (NL) 14−11−03 at 17:16
Almost; the standard front shaft with one-way bearings can be locked by using the optional set #802252; in this set are 2 pins to lock the front shaft (there are 2 holes in the shaft and holes in the 2 driveshaft adaptors and an alu bushing to slide over the pins). Pictures in the product-section soon.
So I guess you need to buy the optional part that locks the one way front.
The shocks are the same as the 705. The yellow springs in the pics look the same as the ones from the 705. But in the FAQ, it is mentioned that there are going to be new optional springs.
SN
#543
Originally posted by S710_Nut
Maybe the Serpent guys can shed some light on these new springs for the S710?
SN
SN
They are still the same.
In the kit will be the yellow springs.
The Springs we have as optional are :
Soft : Orange
Middle soft : White
Middle : Yellow (in the kit)
Middle hard : Red
Hard : Blue
#544
We don’t had changed the springs, or the shocks.
Soft : Orange
Middle soft : White
Middle hard : Red
Hard : Blue
Soft : Orange
Middle soft : White
Middle hard : Red
Hard : Blue
SN
#545
I would imagine all new gear tools will be coming our way also.,Right?.....(pinion gear holder,trans gears,etc?)..
is it still possible to use a HUDY set up with the rear suspension?....
will gear diffs ever be an option?...And how soon will that front ball diff be available?..Reason I ask is that on most of our tracks,one ways don't work well.....and the solid axles don't give enough low sp turn in...
#546
He Rene i hope you can beat me !!
But i will give you a hard time, take you're dp with you because our track support it
#547
cool!! Thanks for the pulley info.I just punched it in my ratio calculator
front 1.8421
rear 1.875
difference 1.0179 on same mm tyres
I like the slight over drive to the front of the car I run a 1.0255 (same size tyres)right now and love it
I'll have to mess with some pulley configurations to see what all I can come up with with all the different pullies I have should be fun
front 1.8421
rear 1.875
#548
Yes, there will be a new pinion gear- and clutch housing holder.
We are also use the Hudy setup-Tool. There will no problem to use it.
At the moment we had not planed to make a gear diff.
I don’t know exactly, when the front diff will be available.
But it will not take long time, because we also know that a one-way or a solid axle doesn’t work on every track.
#549
Re: He Rene i hope you can beat me !!
#550
I like that yall took the time and thought process to develop this car.With all the options available and setup should be sweet!
#551
Re: Re: Re: Re: 710
Ummm, slight front overdrive... Woow, totally new pulleys. Wouldn't the production have benefitted if the 16T front middle pulley was retained and the 24T front and rear side pulley used again? These pulleys are all common ones.
Also with the new sizes the belts run over larger diameter pulleys (especially the front belt) which makes them last longer and run smoother
Julius
#552
The front hollow shaft from the 705 will it work on the car?what about the fc blocks for steering?
#553
Hey Julius Welcome!! So our pullies we have now wont be able to be used on the car?I take it yall have tighter tolerances on the new pullies.
#554
Hey can I ask the time difference between where I am at and you are? Its 7:50am here in the morning.Just wondering my son played hockey over in europe and it was like an 8hr difference
#555
