Serpent 710
#5521
Originally posted by BaxterC
sweet, thanks guys, tell me, the digital servos are programmable, but how does one program a digital servo, I dont neccesarily wan to buy a programmer.
In my opinion, I don't think it's necessary though...
#5522
Originally posted by markp27
What rear end width are you all running? With my still suspensionless 710, if I set my rear width to 199m or more, then the DRS arm starts to catch the centax gear - I suppose this won't happen once I get my shocks on. Anyone had any problems here?
#5523
Re: Some crazy off-the-hip idea!
Well, why not screw the pivot balls in further and then use wheel spacers to correct the width back to 200mm? Is there something I've missed here?
Cheers, Mark.
Cheers, Mark.
#5524
Re: Re: Re: Some crazy off-the-hip idea!
Originally posted by sparksy
Me either. However, radiotray, rear tower, brake plate, front upper and lower bumper have all broken and I have pulled a pivot ball from the hub, not the arm.
Picard, I have also done some very silly things when making adjustments... try running a front and a rear spring on the front shocks, and your rear shocks in different upper holes.
oh, I have ordered the white springs... (and a diff for the front)
#5525
Re: Very Happy
Originally posted by Picard
ID I noticed you have tried the solid front, I am going to give that a try next.
With some changes to the setup, you can make the car drive as if you're on front diffs ! The car turns in easily and powers out fantastic !
#5526
Sparksy and myself found the same thing on the weekend ID, unfortunately it took us most of the heats to figure this out
#5527
Now where did those white springs of mine go
#5529
Originally posted by Profoxcg
I tyed to install my solie axel conversion but the pins wont fit thought the wholes on the diff... should i dremel it open a little? maybe I need instructions.. are there any posted somehwere/
#5531
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Re: Re: Very Happy
Originally posted by InitialD
If you need mind boggling brakes to outrun and outbrake the competition, that's the ticket !
thanks!
mop
#5532
Re: Re: Re: Very Happy
Originally posted by mop_iko
can you provide the link to the post ? coz CAR TURNS IN EASILY AND POWERS OUT FANTASTIC seems awesome to have!!!!
Might or might not work for you. Worked for me though. Perhaps you could make it work the same when using the optional front diff.
I would agree that if the traction is decent, the oneway front is faster.
#5534
#5535
Please let me know "D" how the solid front diff and front diff compare on a small track. I'm interested in hearing about that. Thanks.
