Serpent 710
Old 02-25-2004, 11:40 AM
  #4846
Trader Rating: 17 (100%+)
Thank you all...........I will do the testing on.............3 or 4 months later, snow are still on the ground.
Solara is offline
Old 02-25-2004, 11:43 AM
  #4847
markp27's Avatar
I'm sympathising with you - it's snowing everyday here But, my 710 hasn't arrived yet, so it could be worse
markp27 is offline
Old 02-26-2004, 08:07 AM
  #4848
Julius's Avatar
Default Re: 710 FAQ
Originally posted by markp27
The FAQ also contains a section on drag break.
Here's the latest version for you all!
Cheers, Mark.
Hi Mark,
Just read through your FAQ.
Good info! The only addition would be on the tire section.
First the "setup ride height" is no longer used. So my article about it is no longer valid. The ride height figure in the setup sheet now refers to actual ride height with the car on the tire size as per setup sheet.
On tire hardness: With the 710 I find using same shore front and rear gives close to perfect wear. With 40 shore and harder you may want to use one step softer fronts to get the wear to be even. Use the roll center and other settings to balance the handling.
Julius is offline
Old 02-26-2004, 08:34 AM
  #4849
markp27's Avatar
Default Re: Re: 710 FAQ
Originally posted by Julius
Hi Mark,
Good info!
Thanks for your input - very much appreciated!
Ok, thanks - I'll delete it from the FAQ.
This is with a one-way? What kind of split do you have front to rear?
Cheers, Mark.
markp27 is offline
Old 02-26-2004, 08:48 AM
  #4850
cyba888's Avatar
What kind of tool box do most of you guys use? At my local track most guys use some nice ones that roll around and have couple of drawers from top to bottom, about a little under 3 feet tall. Looks kinda like those Craftsman tool boxes but its heavy duty plastics but smaller. I think its around 120 US$ but its worth it if your serious about organizing your stuff and ease of convenience Now I just need to ask where they get those
Looks something like this.
http://www.acehardware.com/product/i...ductId=1340672
cyba888 is offline
Old 02-26-2004, 08:58 AM
  #4851
Trader Rating: 2 (75%+)
http://www.diy.com/bq/product/produc...60&CATID=72291
Wal-Mart / SAM's Club
Target
PUNISHER is offline
Old 02-26-2004, 09:40 AM
  #4852
Hi all, I have another 710 question, this time, the centax 3.........I am running a Nova Mega 3 port Turbo MS, after puting everything and running the measurement, I ended up these 2 number....1.49mm (when pushed - A dimension) and 1.07mm (when pulled - B dimension)...so I subtract 1.49mm to 1.07mm = 0.42mm
Serpent recommand 0.70mm difference, and they gave an example saying if my different is GREATER then 0.7mm then use this formula A - B - 0.70mm = whatever and add the whatever MM thickness shims outside the thrustbearing............but me, my final number is LESS then 0.70mm......am I suppose to TAKE OUT something..? But I have nothing to take out...so what is next?
The only area I can think of is my "B" thickness is OFF, Serpent example is 0.30mm and I have 1.07mm.....and my "A" number is very close to Serpent......do you think my "B" number 1.07mm is the problem?
I am sure this is a dumb question since I did't see anyone asked that before....but I don't want to spend 5-7 days to figure it out, might as well ask you guys and the Serpent tech team.
Thanks..............
Solara is offline
Old 02-26-2004, 11:12 AM
  #4853
Hello all!!
Here is my 710 powered by R&B V12T
maximummt is offline
Old 02-26-2004, 11:14 AM
  #4854
Julius's Avatar
Default Re: Re: Re: 710 FAQ
[B]Thanks for your input - very much appreciated!
[B]
Cheers, Mark.
This is with one way and diff. Although tire hardness is a powerfull tool to balance the cars handling, I try to get tire wear as even as possible.
I start with a 1mm to a 0.5mm split. Overdrive is then 1:1 or a very slight overdrive to the front.
Julius is offline
Old 02-26-2004, 11:16 AM
  #4855
Julius's Avatar
Did you take out one of the ball bearings before you measured the A (pushed to the shoe) measurement?
Julius is offline
Old 02-26-2004, 11:20 AM
  #4856
Diesel Racer's Avatar
Rookie, first things first, double check the thickness of shim that you placed between the brass collet and engine output bearing, this should be 0.5mm. When checking your A & B dimensions that should be with just the thrust bearing installed not the 2 small ball bearings.
Good luck
Mark
Diesel Racer is offline
Old 02-26-2004, 11:35 AM
  #4857
markp27's Avatar
Default Re: Re: Re: Re: 710 FAQ
How would you go about choosing which tyres to use?
Cheers, Mark.
markp27 is offline
Old 02-26-2004, 11:51 AM
  #4858
serpentracer1's Avatar
I got a nice rolling box from walmart in the fishing section looks just like a stanleydual roll box but is way cheaper and more compartments
serpentracer1 is offline
Old 02-26-2004, 12:01 PM
  #4859
markp27's Avatar
Originally posted by maximummt
Hello all!!
Very nice maximummt
Have you ran the car yet?
markp27 is offline
Old 02-26-2004, 01:01 PM
  #4860
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default DRS
Hey InitialD:
How much does the car toe-out when the car accelerates?Does it make a difference on how much ride height you have?
Thanks in advance
Marcos.J is offline
