Serpent 710
#4501
Originally posted by r12 schumacher
thanks for the correct word, atleast i was in the correct idea
#4503
Originally posted by Pit-racer
It will make it's debut this weekend w/ a hand modded Palmaris NS12 Novarossi ....
That's a nice ride Pit !
Give them hell !
p/s: Are you using Power tires? YGPM.
#4504
Originally posted by markp27
If you can afford it, then go for a tyre truer, then you can start to size yours tyres with differential between front and back, so that they wear at an even rate.
Perhaps InitialD (or the other knowlegable guys) can give us a little lesson in tyre sizes (split ratios etc) which I can put into the FAQ for future reference.
If you're using stock 17T/60T for 1st gear and 22T/56T for 2nd gear, then your 2nd gear tire rollout with 64 mm is 42.127 mm / engine rev. With 60 mm tires, you need to change your 2nd speed pinion and spur to 23T/55T to give you about the same rollout as before at 42.04 mm / engine rev. Then for 1st gear, back calculate about 5 or even 6 tooth down for the 1st gear depending on your engine. With the new 0.8 gearing module, it is possible to use a big jump in the 1st and 2nd gearing without bogging the engine down much when 2nd speed engages.
#4505
Originally posted by InitialD
[B]Rub it in with the tire truer man...
#4506
Re: Re: Filter
Cool. Looks like you got the new one. When did you get your kit?
#4507
Are you referring to running the external filter with the 705 tank or the 710 tank?
The 710 tank (with the bronze filter) never needs the external filter to run properly.
and it had a similar filter to the 705 in it, I never ran a 705 and never ran a external filter with the R12
#4508
Re: Re: Re: Filter
Originally posted by Picard
Got my kit 2 weeks ago from HK
#4509
With the updated tank with the bronze filter that is supposedly coming with the 710, you can reduce the tank volume by using inserts.
#4510
Re: Re: Re: Re: Filter
Thanks for the info. Then Serpent should already be shipping these revised tanks with the kit.
#4511
You think the new 710 tanks will be available as an option part? Will the old tank have more capacity than the new ones since there is an internal filter?
#4512
From what I read in the book, you have to intall inserts into the tank to make it legal so the tank must be oversize. Therefore it is not small
#4513
What bodies was used for the winternats? Which bodies were being used for the top 3 drivers?
#4514
Over here the popular 2 bodies are the Alfa 156 2.1and the Stratus 2.1. I usually use a stratus but will try a alfa on my 710
#4515
Where do we get these inserts from ID?
