Serpent 710
#4351
Re: Watchout !!
Originally posted by GoldFinger
Just pay more attention for this car ....
#4352
Sorry for being so long..
Here s what I mean bulletproof bumper
Front View :
Front View :
#4353
Originally posted by cyba888
Does the factory charger that comes with the Futaba remotes charge ni-mh batteries? You know the one with 2 red lights on the adapter,1 for the rx and the other for tx? Actually I found one laying around but its a Hitec one. Not sure if it will work with a Futaba remote. The polarity should all be the same correct? Im guessing it should be universal.
Here are the specs for the Hitec Ni-Cd charger.
Input 117VAC 50/60Hz 4VA
Ouput TX 10.8V DC 55ma
Rx 4.8V DC 55ma
Should I see if it works or is it too much of a risk?
Rx 4.8V DC 55ma
#4354
Is there any normal wear and tear I need to watch out for on the 710? I heard someone mentioned that some kind of shims need to be replaced as they get worned out?(forgot which ones) Im talking about anything doing with the clutch, gears, thrust bearings or anything similar?
As far as clutch is concerned, I'm very happy. I only damaged the 1st gear pinion due to an accident. The pinion hit the tarmac. Spurs are also very durable. I have not changed my spurs yet after running close to 2 gallons of fuel.
Because of that accident, I think some metal debris went into the 2 small bearing and damaged them both at once !
Thrust bearing? Never failed a single thrust bearing since I ran Centax clutch on the Impulse. If you install and lube them properly, they will never fail.
#4355
Originally posted by Pyramid
When the pinion gear (standard) and spur are worn out, it`s better of changing both at the same time to avoid stripping. Shims on the first gear also.
Madness... I think that`s driver factor. S710 has blast MTX3 on its firts meeting by overlaping in 5 minutes run in here.
#4356
Re: Watchout !!
Hey Goldfinger, it looks like you lock the front one way. Is it? How do you find it? Any difference in setup from one way front that you did on the car?
Also, you're still mounting the steering linkage on top of the servo saver?
#4357
Re: Re: Re: Watchout !!
With stock 710 bumper and plate.. i gave up already after replace it 4 times.
#4358
Anynody out there that has some detail pictures of Ralph en Michaels car?
#4359
The cars or the bodies...?
#4360
Re: Re: Re: Pinion Gear Aluminum Washer
Got plenty of it :
SER-802511 Centax-3 Gear Pinion Shim.
This is a must spare on your box.
2 or 3 clutchbell with several pinion combinations will be more handy.
Got plenty of it :
Serpent Doesnt Even list them on MYTSN, nor does Serpent USA on their site.
Curios to know if anyone could let me know where I could find some for purchase.
Good Luck To Michael Salven, Ralph Burch Jr., and Jared Scott, Scott Gray, Etc.....today at the finals in Florida !!!!!!!!!
#4361
Re: Re: Watchout !!
Yes D, Im back to the top (servo saver) mounting one. The bump in condition when the car leans is adding more steering lock, which is i needed most.
For the Ti screw, I replace all the M3 screw and manage to save near 30gr to compensate the alu shock body.
#4362
Re: Re: Re: Re: Watchout !!
Ummm, you must be hitting the front on hard impacts. I've replaced the top plate once and the bottom one twice so far. All those times it was in the Thailand race.
It was 4"height concrete wall..
#4363
Anyone?
Anyone?
#4364
Is it safe to charge my tx batteries if I connect the wires to my Tekin charger while its in the remote socket? Look at attached files. Usually when the charger is NOT connected to the wall I get a volt reading when its connected to the batteries. But when I tested this method out I didnt get a reading. Do I need to charge it first to see if it will actually charge without damaging my radio?
#4365
Is it true that ABS will damage your sevo on the long run? People tell me its not good for your servo. Anyone here use ABS?
