Serpent 710
#4306
Originally posted by SupermaxxRich
Well, I've decided to purchase the 710! Can't wait to get it! Can anyone tell me where I can purchase the Front Diff for the 710? Also, what is the largest battery pack for the 710 and where I can I get that as well? Thanks. Please let me know soon as I would like to get these items ordered asap!! Will the 710 work with the Ofna Starter Box?
Battery packs can be made by yourself, if you are competent with soldering - otherwise there is a battery pack available from serpent (they are AAA re-chargeable types). Have a look on the mytsn website under the 710 product page, there is probably some info regarding the battery pack.
Not sure about the starter box.
#4307
#4308
#4309
#4310
Originally posted by markp27
710 has winternats 1 and 2 places on the 200mm grid!
http://www.mytsn.com/news/publ.asp?pid=9604
#4311
Re: Tyre truing
Does anyone know if it is better to run new tyres a few laps before cutting them to size with a tyre truer - i.e. breaking tyres in?
You do not need to run in the tires on the track before cutting them down on the truer.
@D: What was the rule with the droop regarding using full sized tyres?
#4312
Originally posted by cyba888
I believe the Ofna should work with the 710. Was it InitialD who has one that works with the 710??
#4313
#4314
Originally posted by InitialD
You can try the border located in Holland or Mark's link to RCCarinternational also in Holland.
If this is the pre-sales service, I don't even want to know what the after-sales service wuold be like!!!
#4315
Re: Re: Tyre truing
Full size tires are like 66 mm if I'm not mistaken. The kit stock setup recommends 62 mm at 6 mm front / rear ride height with 0 front and 7 rear droop. If you use 66 mm, set the car to 6 mm ride height for the front and rear as per the stock setup and decrease the front and rear droop by 2 (66-62 = 4, 4/2 = 2). So you should use +2 front and +9 in the rear when you use new out of the box uncut tires with 6 mm ride height.
#4316
Im still confused as to what "droop" means. If it has anything to do with how low the arms move, wether its up or down then it would be the same as ride height? How do you measure droop, with a ride height guage?
#4317
I'm not at all impressed with the Border shop - they ignored my emails about a price for the 710. Plus I sent a PM to the guy from the Border who posts here - nothing!
Well perhaps after that "incident", he decided that you were jinked and that he did not want to do business with you anymore !
But heck, I now try to avoid EU online shops. I mean the the exchange rate is simply sick. The US dollar going down is not helping !
#4318
Re: Re: Re: Tyre truing
Thanks! the /2 is due to the need to correct the radius of the tyre and not the diameter
#4319
This is what the Serpent 710 setup book has got to say about droop or what they also call downstops...
Downstops limit how far the suspension arms travel downward, which determines how far upwards the chassis rises. This affects the cars handling, as it directly impacts the weight transfer of the chassis. The effect may change with the type of track and/or amount of grip available.
In general, more suspension travel (lower downstop value) makes the car more responsive but less stable; it is also typically better on a bumpy track or on a track with slow corners. Less suspension travel (higher downstop value) makes the car more stable; it is typically better on a smooth track.
Reduced downstops (higher downstop value)
decreases upward chassis travel
car more stable under braking
better on smooth tracks
Increased downstops (lower downstop value)
increases upward chassis travel
better on bumpy tracks
IMPORTANT! Adjust the downstops so the left and right sides are equal.
#4320
For those running rubber tires, you never need to worry about changing droop as rubber tires never wear !
For foam tires, ride height changes when tire wears and when you change the ride height to accomodate this tires wear, you need to reset and compensate the droop accordingly.
